Mike do you find that cd quality 16/44 recordings are just as good as say a DSD recording or can you still tell the difference ?
your question has no simple answer. but i will tell you how this looks to me.
oh yes, there is a difference between redbook and dsd. but how can we hear the music at it's best?
i find that any recording sounds it's very best in it's native format. so if it started as a 16/44 recording, then that can sound very very good. and i would likely prefer that 16/44 recording to a dsd transfer of it. but then you introduce the dac and server or transport variables and that can change that equation.
most recordings these days are higher rez PCM of some sort. and these can downsize to 16/44 very well. many times a 16/44 transfer of a higher rez PCM recording will be preferable to a dsd transfer since the transfer math is simpler.
if it's an analog recording then dsd might have an advantage in the transfer if it's done optimally.
but again i'd rather hear the higher rez PCM recording in it's original format than any change, as well as any dsd recording.
ok.....that's a lot of information.
simply put; CD redbook is still where i find lots of music and it can sound fantastic. 4-5 years ago i was a dsd snob and wanted most music in that format. but that was because my dac converted everything to dsd, and PCM dacs were still getting better. now the best dacs are equally good at PCM and dsd so now we want native files when we can get them.
Best USB cable I never heard....if u are using MSB Pro USB run to this.
IME Qobuz (almost always) sounds better than TidalLet me change that, if your already subscribing to Tidal or Qobuz do you then need to go and subscribe to Roon if you buy the Extreme or Evo or can you use something else in its place ?
IME Qobuz (almost always) sounds better than Tidal![]()
You don't have to subscribe to roon but I seriously recommend it because roon is wonderful to use and to discover new Music
I would want to have roon I were you![]()
Christoph thanks, I did have it before when I had a Devialet and a DCS dac, I just found having the Mac on all the time when running it a bit of a pain but if its better with it than without then maybe that's what I will have to do.
Can anyone correct me on this, do I need to connect the Extreme or Evo to a dac before it goes to my Amp or can I use the linestage on my preamp instead ?
I'd be interested in any users who have a SGM server but whose dac doesn't have a usb input, do you use a card with an AES/SPDIF out or do you use a usb converter ? And which one sounds better or is the difference not noticeable, I know I might have asked this yesterday but I would appreciate other users experience in this area and what their thoughts are
AES/SPDIF is only a high quality datastream if you have an external clock to synchronize the whole system. Probably Emile will chime on this subject, but considering the Extreme does not have clock input or output lines and is essentially an asynchronous server I think that the answer will depend on the particular DAC and USB converters being considered.
You remembered me I have a Berkley Audio Design Alpha USB converter somewhere, I must try it with the Kondo KSL DAC!
Hi microstip.
Since you seem to be a person with extensive experience with high quality devices, you would be interested in reading your impressions of the Extreme.
walk on the wild side Micro, do ya good!Still feeling it is too good to be true! I must cool down a bit before posting too many superlatives on it ...![]()
