Of course they can be simple if you don’t care all that much about linearizing impedance or frequency response. I have experienced situations where the removal of one of these networks completely improved the sound despite measuring worse. Did you start simpler and advance to this complexity?
Ah so you are doing the Geddes foam thing in the horn as well?
My family horn system![]()
what compressing driver do these use?
Odeon La Boheme. The horn is either a Tractrix or Spherical, not sure which. Not on stands , it is a back loaded TQWT so the whole bottom is open and the gap to the base sets the amount and speed of the bass. The tweeter is a Beyma CP350Ti 1 inch compression driver and the mid/bass is an old but very good Focal paper cone (famous in France for Onken box designs). Sensitivity around 97db.Nice what are they?? That a tractrix?? Up on stands it that a midrange/midwoofer with an internal subwoofer?
Rob![]()
The driver is a Beyma CP755Ti.
Wonderful sounding Beyma CP350Ti. It was also used in the very exotic Jadis Eurythmie II horn speaker from the late 90s.what compressing driver do these use?
Beautiful little speaker. You are using the CP385Nd on that one? Maybe you can see on the floor of my upstairs system photos a small pair of horns on each side the speakers. That is a pair of CP350TIs I picked up used (rare and not so cheap) mates to some small 18 Sound XT120 elliptical horns. I will eventually see if they outperform the CP755Tis crossing around 1500hz. The CP350Ti has very low measured distortion and basically no breakup seen despite being a pure Ti diaphragm. Maybe a TAD is better but then it must be REALLY something special.Beymas are excellent in my experience. I haven't used any of the large-format Beymas yet, but the CP-385Nd is very nice in a small-format driver.
Ime it's a good idea for the driver's exit angle to match the horn's entry angle (or at least come close). Your statement that the CP-755Ti on the 18Sound XT1464 sounds "very uncolored" makes me think you either paid attention to this, or the audio gods were smiling on you. (Not that I take every DIYer's endorsement of his handiwork at face value, but you have credibility in my opinion.)
By the way, lovely little speakers in your family room system... Odeons, I presume? [edit: I was typing while you were replying to Rob.] I'm working with wooden horns now as well:
ive heard the Jadis, without a doubt an excellent sounding speaker.Wonderful sounding Beyma CP350Ti. It was also used in the very exotic Jadis Eurythmie II horn speaker from the late 90s.
I am tempted to get an Iwata 600 and JMLC 600 from Poland to see how they compare with the 18 Sound ESS Elliptical constant directivity horns I am using now. These sound very uncolored.
View attachment 57923View attachment 57924
(...) It was also used in the very exotic Jadis Eurythmie II horn speaker from the late 90s.
It was one the speakers I considered for the Lamm ML3. Although rare we can get them in Europe
around 20 ~30 Keuros. What is the general opinion about it? It got a very positive review in Stereophile in the 90's, https://www.stereophile.com/content/jadis-eurythmie-ii-loudspeaker the hifi press did not ignore horn speakers!
Considering the AvantGarde range of models as a scale, where you would you situate it?
Did you consider a pair of Trios with the horn subs? Would think they’ll work with your Lamms and they have decent resale / support if the latter is important.
(...) Although I love my current speakers, now that I have more room I would buy a pair in a heartbeat if they came up.
Interestingly, it appears that Avantgarde is using the Beyma CP380m as the tweeter in the Duo series and Trio series. This is the successor to the CP350TI and appears from specs to be the same motor but with a plastic dome instead of a Ti dome.Did you consider a pair of Trios with the horn subs? Would think they’ll work with your Lamms and they have decent resale / support if the latter is important.
