For those with lots of experience with this brand, I'm wondering if there is a 'sweet spot' in their lineup.
I too had heard that the Eminent GL is the best buy for the money. I was hoping to stretch for the Signature Gold but will settle for the Eminent GL if that isn't within reach.There are quite many saying the Eminent GL is the best buy for the money, having been using the Hyper Eminent for few years before upgrade to the Signature Platinum. I can only say the SP is way better than the HE.
I am not sure the price in the state but you could find it easily in Tokyo Japan when i was in a trip, they usually have full list of models from Eminent GL to Platinum Sig. I think the SG is definitely the way to go without regret if you could stretch it.I too had heard that the Eminent GL is the best buy for the money. I was hoping to stretch for the Signature Gold but will settle for the Eminent GL if that isn't within reach.
I had my MSL Platinum go direct into my Phono amp, no matter how I played around with the impedance on my phono, it just did not sound quite correct. Especially on some familiar vocal vinyl, it sound wired and pitch a little higher than normal.
Until I bought and plug into the MSL SUT 1030, it sound much more natural than not using it.
I wonder if the MSL carts are developed using their own SUT for voicing? Would seem to make sense. My Ikeda 9Gss sounds lovely through the MSL SUT as it does through the Airtight one at the moment.The 1 ohm impedance is pretty much the same as Opus1. Using the SUT will likely alter the cart's original sound at some extent. My view might be different from others here. I don't find the MSL Plat and Opus1 which very much resemble to MSL Plat to be any more sensitive to loading than other carts. I used to have an Airtight SUT. I even tried it with the Airtight Opus1 and MSL. I found them lost resolution and there was even a change in tonal balance with the SUT. I also tried MSL Plat with three different phonos. It sounded consistent to all three. No problem with loading.
Kind regards,
Tang
I started this thread simply because the MSL range, more than any other cartridge I know of, meets my cartridge requirements in terms of specs:
Output impedance <11 Ohms
Output: >0.3 mV
Loading: ~200 ohms
Mass: <10 grams
Compliance: low (or medium-low)
I've never actually heard any of their offerings.
May i ask why those specific requirements?
Many thanks. Makes perfect sense then.Of course.
My phonostage has a built-in SUT. From the manufacturer:
"The loading is closer to 200 Ohm and it is a transformer load which is a bit different from a purely resistive load.
I usually recommend cartridges with output impedance of 10 Ohms or less and output level of 0.3mV or more."
My tonearm is a linear tracker. From the manufacturer:
"You need a low compliance, light or medium weight cartridge. Less than 10 gr."
My MSL Ultra Eminent EX sounded a bit buttoned-up for the first 50hrs or so and then it really began to come alive and has become quite transparent although with just a bit of "sweetness" in the high frequencies. Not rolled off, mind you ..just a bit "burnished" It's certainly not Clearaudio Goldfinger revealing but is highly musical and enjoyable. Sounds really wonderful direct in to my Accuphase C-37.I heard the MSL Platinum recently. Out of the box, it sounded very smooth. Too smooth. I wonder if its smoothness reverses over time or if this is the long term signature of this cart. Any thoughts?
