Thanks to all the positive reviews here on WBF and my desire to elevate the sound quality of both the Aqua Formula XHD and the SGM2015 I purchased two of the standard sized Daiza platforms which arrived today. Packaging was superb and both units arrived in perfect condition.
The photos show the top and underside view with the spiral cutout and the 3 foam inserts. Sturdy feet are supplied and you can see from the photo that these also have foam inserts. Neither inserts are to be removed.
I will post listening comments after a few days once I get a handle on what they contribute to the overall system sound.
Initially I’ll listen with one under the Aqua, then I’ll install the second under the SGM2015. You may notice I’m using Arya Audio RevOpods inverted under the Aqua to give a ‘tighter’ connection to the platform. I intend to try the RevOpods under the SGM after listening with its stock feet.
