For those of you sound stage critics, this had a much higher sound stage despite the diminutive height of the O References.
I sat (hogged) sweet spot for 40 minutes and in general thought they were Devore to a "T" - highly musical, but more refined and very dynamic. I am not going to give a full review under the listening circumstances. Also, no bass heavy information was played (to my dismay and others- one cut we could hear the room leveled but only for 2 seconds). The system was on Nagra front end with EAR mono amps.
I spoke with JD at length about the design - and came away very impressed. He's thought of so many details that the pictures don't show. All the drivers are basically new except the dome of the tweeter. The brass horns take away resonance that was being absorbed by the former polycarbonate horn used in Orangutans. The cabinet is differently shaped towards the rear for more volume and a blend of Orangutan and the Silverback designs - with "D Mass" extensively used inside (sorta like carbon fiber apparently). The A cabinet still is tuned in typical JD fashion and the ports don't touch the cabinet at all and tie into a large bottom plate. I believe he said the speaker weighs twice what an Orangutan does with the cabinet changes as well as the beefy Alnico driver-based mid range with bronze casket. The bass cabinet was switched to a passive radiator design as the force of the woofer was much higher than initially anticipated. He said a 6" wide port that is 6' long was what it would have required to retain a ported structure for this monster woofage. Also, the "B" cabinet doesn't have to be side-by-side just that it takes more of the room away which he prefers in these kind of environments. He included phase and two additional frequency controls to help room placement.
I think folks may have issues with Devore *ever* selling a $85k loudspeaker as his brand specializes between $5k-$15k, but the thought, materials, and design are clearly there. The sound definitely had promise, too.
