We used M's powerless FTA Callisto for our Lampi(s) vs. Kassandra shoot-outs and it worked flawlessly with the fat SandyI will consider that. The Kassandra does need the handshake, I tried without and it won't see the source.
Well, what happened? How did the comparison go?
Why would I?Do you have some dealer disclosures to add to your profile Christoph?
I think we both know you are a bit more than a happy customer Christoph. I have no problem with you selling stuff but you have crossed the rubicon from my perspective today.
Christoph, we are having this conversation today because you have chosen to put down my product in order to promote your friend's brand.
You claim to be 'just a good customer’ however in my experience good customers do not possess multiple examples of usb cables which they are keen to run around demo’ing to other people. They may occasionally post an appreciative word online but seldom multiple posts on the same subject. Furthermore, they would not feel the need to link their posts to other threads, like you have done today, nor show such keenness to report comparisons against perceived competitors.
I do not believe that I know Audioquattr personally and couldn’t say exactly which model or generation of my cable he has, though like most things in life my designs are continually evolved without announcing to the marketplace.
I know Chris Personally. He is NOT a dealer for FTA at all. I also know where he works and it has nothing to do with audio.
The Wireworld Platinum sounded broken compared to the Final Touch Audio Callisto USB cable when we compared them. I begged my friend to take out the WW Platinum and re-insert the FTA Callisto![]()
As an industry friend of mine pointed out, when you implement a full loom from a single manufacturer you get that manufacturer’s vision of how his/her cables should perform. I’ve taken this advice on several occasions and in generally it brings extremely satisfactory results that are difficult to improve on with any kind of cable cocktail. I currently use a full Synergistic loom of power, speaker, interconnect, ethernet and USB cables and substituting single cables from other manufacturers generally results in shortcomings, due to the introduction of a ‘foreign’ character. Even placing a USB signal regenerator in the final USB link robbed the system of some of its magic.It's interesting because I've had a similar comparison with the Synergistic USB in a client's system, but when I got back home to my system, the Platinum Starlight exhibited none of the issues we found in his system. The client had an almost full loom of Synergistic cables whereas my system was completely Wireworld, so I'm thinking there might be some synergy going on with the different looms.
Sorry to read about your woes.Sorry for bumping. Hope this is relevant. I had a Callisto I used with my Lampi TRP and Lucas Domensky's server. It sounded very nice but was bested by David LaBoga's Ruby USB which Lucas D. recommended (roughly 3X price of the Callisto). The Ruby kind of crapped out yesterday, losing lock within a 20 minute time span. A cheap AQ cable worked fine so the Ruby will have to be replaced (under warranty). I bought an Intona Ulitmate today because I'm not sure how the Ruby and TRP will ultimately work together. I believe the issue is neither the cable nor the DAC per se, but rather than JL Audio USB card I had Lampi install last year. It's kept kind of quiet but I have heard of a number of issues between certain cables and the JL USB. The TRP Amanero USB worked fine and in complete honesty I heard no upgrade in sound related to the install of the JL. I know Lukaz from Lampi likes the JL but IMO if your Amanero works fine just leave it alone.
Now I am almost back to square one. I'm getting a new Ruby but it will take a month and I'm not sure it will work right in my system long-term. In the mean time I had to spend $2k to buy a back-up USB cable (the Intona) which I've been told I might like best of all. I have been an audiophile for 45 years, and while I LOVE the hobby the lack of 'plug and play' between components/cables/etc makes me almost want to buy a mass market system that just works. Venting now but I have had a lot of issues with components and cables over the past six months that I don't think one should experience in a $150k system.![]()
