WAVAC are also priced in a league of their own ... $350,000/pair ...It could be said to be really out there .. although it is TWBAS .. Are they really that special? Just asking...
Can you expand on that? I'm moved more and more by high sensitivity speakers as I feel that power hungry speakers are likely to compress and distort at high SPL, though I don't know if that's necessarily true.I remain unconvinced that the low power/high efficiency path can get you to SOTA, because of the nature of very high-efficiency speakers.
There are, no doubt, exceptions to the rule, but speakers likely to reach realistic levels when driven by low-power amps are likely to be horn-loaded, and they create a whole new set of problems.Can you expand on that?
Hi Keith. The answer is: it depends. 25 watts SETS, even on efficient speakers, still will be insufficient depending upon certain factors, including, without limitation, how loud one wishes to listen to music and the crest factor(s). Tim has got it exactly right: headroom. Having stated that, there are plenty of tube amps that are high powered as well as less than mega buck SS amps, so what you presented is a false dichotomy between low powered SETs and mega buck SS. I have no opinion on the other dichotomy you presented; I have no data to support or refute your claim except that, if you are right, then you are reading a post from the 10th personRon- 25 watt SETs on the right speaker should not have dynamic restrictions---care to say why i'm incorrect? and therefore in your opinion the only SOTA amps are mega buck solid state? we can agree to disagree if that's the case. 9 out of 10 people will take Steve's Lamm setup over a Spectral setup would be my guess.
That's not necessarily true. But if you're not willing to go active and/or pay the price for very high-powered amps, high efficiency speakers will probably give you better performance.
Tim
I doubt it. i can't believe any set of amps costs more than a Porsche Turbo RS, but that's me![]()
Hi Keith. The answer is: it depends. 25 watts SETS, even on efficient speakers, still will be insufficient depending upon certain factors, including, without limitation, how loud one wishes to listen to music and the crest factor(s). Tim has got it exactly right: headroom. Having stated that, there are plenty of tube amps that are high powered as well as less than mega buck SS amps, so what you presented is a false dichotomy between low powered SETs and mega buck SS. I have no opinion on the other dichotomy you presented; I have no data to support or refute your claim except that, if you are right, then you are reading a post from the 10th person.
If you saw my first post in this thread, three of the four suggestions I made were active designs. Active is interesting and sensible, though Dr. Geddes directly contradicted some of my preconceptions with regard to its benefits. Particularly that well designed and specified passive crossovers aren't much trouble when measured and inaudible when compared directly with active designs.
When it comes to amplifier output, I define 'very high' as 300-400 watts. That's more than enough for any small room (i.e. not a stadium), but 100 watts is plenty. I would prefer to cull any speakers less than 88dB sensitive from my shortlist - with exceptions. Horns aren't my cup of tea, mostly because I won't dedicate the space required for high performing horns, though Danley and JBL models are exceptions. So I'm biased towards highly directive designs featuring large, sensitive drivers with a relatively high frequency high pass. I am convinced that an independent subwoofer's placement options can increase fidelity over a full range speaker.
There may even be some designs in which passive and active cannot be differentiated, but I have serious doubts, particularly when active is done properly, with the amps purpose-designed or chosen for the individual drivers in the system. Simply taking the same amps and placing them after an active crossover will not optimize an active design.
Tim
Jack, I'd add VTL and Grellman's as well.
I've never heard of Grellman amps Ron. Can't find anything on google either. The closest I got to Grellman + Amps was a story of Jacob's visit to Steve's, Mike G's and Wolf. Gotta link?
