I have but unfortunately due to space and WAF considerations I am limited what I can do.Just a suggestion, have you considered yr tt on a dedicated stand?
Thanks, I will investigateWall shelf? The best solution of all.
I liked the idea of an SRA under the table. I have the SRA Ohio XL+2’s under my amps and love the result. Thanks for the suggestionsbeautiful! Congrats on the new upgrades...i wonder if you might investigate SRA? While it is 'another' audiophile thing...at least they are piano gloss laquer and would sit directly under your Triangle. I use HRS M3X, Stillpoints U6s...but for the Zanden Digital, the SRA Ohio XL has been an eye-opener in what it does for the Zanden.
Fantastic! Great to hear...and yes, i should have noticed those.
By the way...can you speak about the PS Audio P20...i am most curious as to how you might have found it compares with other power conditioners. I see that you are using the Shunyatas as well. .....
I like what the P20 has done for my system. It cleans up and regulates the power and makes my system more musical plus I need the outlets. I use to own the Denali 6000T and Gigawatt PC-4+ Evo but the P20 surpassed both of them. The only negative is My ARC Ref 250SE mono-blocks will shut the P20 down - the 250SE’s draw a lot of voltage. Therefore I must have the 250SE’s go through their own Denali 2000T which works for me.
Why did you get the mods to the Sonos Connect? Doesn't the dCS DAC reclock it anyway?
Thanks Ron and it sounds equally fantasticCongratulations, Jon! The set up looks fantastic!
Hi, Let me first state the Tidal Agoria Silver ed. and Alta Audio Hestia Titanium’s are at a different performance level and price point (100k difference in retail price). With that said I loved the Hestia Titanium but must state you definitely need a big room to maximize their performance and to not be overwhelmed by their bass performance. The Hestia’s are some of the best performers in creating or reproducing a 3-dimensional soundstage that is easily discernible and maintained off axis like no other speaker I have encountered. The Tidal Agoria’s which I first heard at the 2018 Capital Audiofest were the star of the show for me and led me to purchasing the Agorias. The Agorias are at another level providing a more balanced sound with greater detail, dimensionality, dynamics, transparency and better tonal and timbral accuracy. They don't go as low as the Hestia’s but provide a more accurate bass reproduction. I owned two Alta Audio speakers (Hestia’s and Celesta) in my lifetime and I was able to sell both within 30 days of placing an advertisement, however at 50% of the retail price. Both are very musical speakers and you get a lot of performance for the money. Mike Levy of Alta Audio is a great designer and produces great speakers that out perform many speakers at double his speakers price points. Hope this helps.Hi, I was considering the Hestias until I happened across your posts and noticed you moved from the Hestias to the Tidal Agorias Silver. I'd love to hear your thoughts and findings that led you to make the change.
And I wonder, was it hard to find a new home for the Hestias?
thanks so much !
