Where do you guys (who find GG better than Pac) listen to mostly, Pcm or DSD?
I believe some converts everything to DSD ?
Lampi dsd and pcm are always separate and purist. No mix and matching.Where do you guys (who find GG better than Pac) listen to mostly, Pcm or DSD?
i for one listen about equally to both formats.Lampi dsd and pcm are always separate and purist. No mix and matching.
Can you share internal pictures of your Lampi where you have the different caps.
Haha. Taking it to next level shytt. Cap rolling. Almost as bad as AL with...cap vs direct no cap switch!
I can but why do you want to see it? Just curious...
As for passives, the Ypsilon PST is considered to be one of the best preamps. It just so happens that it works with 242s, as does the Analog Domain passive, and the Aries Cerat Active, which makes them my preferred preamps
Hi Kedar
You often say the 242 doesn't work with ARC gear but I can tell you from my own experience that - at least in my system - the ARC REF 6 preamp and the ARC REF 75 poweramp worked wonderfully with the 242 and they worked together as well as alone combined with my stuff (KR Audio Kronzilla power amp and Aries Cerat Incito pre amp).
I really think you should refrain from your gross generalizitions you like to trumpet as dogmas (aka your findings of the day)
A few thoughts on this rather confusing thread.
For the record Lampi has done somthing with the network input. The pacific I had for my mini review did sound as stated but when it came back from Lampi the network input sound had changed drastically for the better. There is no longer a NAA only RAAT
For what ever reason this gives this input a very much on par with usb now. It's a bit more forward to my brain but wonderful.
This was done in my room on same TRI pc setup cust made by me.
As for Kedar's continued observation this eludes my conception as to how he and the other 4 other Golden ears claims I can only say this.
In my room on my stuff I have had the big 7
My quasi head dac gg 1
A gg2 new model same engine as pacific in fact on the same day all played. The moment I put on the gg2 in 10 seconds I asked the owner if he had the same engine it was obvious.
The pacific is a clear winner across the board. Yes it needs a pedigree of tubes but levels above the others
For what it's worth Lampi continues to move up not sidways as some may say.
Having a preamp regardless of what many say is a must. This pre must be an active pre NOT a passive
Interconnect length matters anyone who uses SE cables more than 6 feet nominal or 10 with ultra shieldeding are loosing resolution , slam , Clarity. The very items described as being Better.
Better is a fact and no one gets to say well mine has this. Better is a culmination of many factors
What good is slam without jump or clarity.
Glazing is also part of a less than optimal setup.
Owning a system is far more important than making judgements based on hearing ones stuff at place not yours. Anyone who does not own can have there opinion but they should be aware of a less than accreted conclusion.
An example is this. Lets say a given system has a tube amp this setup most likely cannot keep up with the dynamics of a pacific dac. It's off the chain dynamic and jump. A Low noise floor yields dynamics but jump needs a fast powerfull amp. A tube amp runs out of gas but clips soft where a ss amp shouts. Given a jump is not there due to this effect on tube amps ina less than optimal system.
For any nay sayers come to my room and bring your dac then post as you hear things.
Being here it's obvious that each level of Lampi is clear in class jump.
Ps the pacific plays pcm better than dsd in my world but both are world class. To comment that lesser models are better in any comparisons to the pacific is just confusing to me.
Perhaps the systems of the nay say groups cannot Produce what the massive change is.
Hi KedCompares were PCM only.
Hi Ked
Have you been able to compare your GG to another PAC in the meantime?
I'm really curious about that outcome...
