Hi Kal can I had the av7702 to my av8805 and mm8077 to go to 14 channelsMM8077 Is only 7 channels. If you plan to run more channels, you will need more.
No. The 8805 is capable of 13 channels but, to use them all, you need 13 channels of power amp. The 7702 is a prepro, not a power amp.Hi Kal can I had the av7702 to my av8805 and mm8077 to go to 14 channels
That’s what I thought thank youNo. The 8805 is capable of 13 channels but, to use them all, you need 13 channels of power amp. The 7702 is a prepro, not a power amp.
Thank you NorthStar that helps a lotYour Marantz pre/pro is a 13.2-channel surround sound processor. ...With the additional option to add two more speakers to make it 15.2 (but only a maximum of 13.2 can operate all together).
The two extra channel speakers are simply an expanded option in positioning, giving you more versatility, flexibility in experimenting, etc.
Your pre/pro is quite sophisticated and with many desirable features for a full fledged high caliber home theater surround sound system...Audyssey MultEQ XT32 (Platinum), Dolby Atmos, DTS:X and Auro-3D. ...Plus so much more that it would take a book or two.
If your goal is say to have a 7.2.4-channel system (11 speakers plus two subs - 7 main speakers, 2 subwoofers and 4 height ceiling speakers), an amp like this (5 channels) would do:
• https://emotiva.com/collections/amps/products/a-500
With your 7-channel Marantz amp you'd have 12 power amp's total, one extra.
If you want to go the full capability of your Marantz SSP (pre/pro), you would need another mono amp, or don't get that 5-channel amp above and look for a 6-channel power amp instead (more rare), like this one for example:
• https://www.amazon.com/6150-Home-Theater-Reference-Amplifier/dp/B001GL0K7K/ref=sr_1_17?s=tv&ie=UTF8&qid=1550950189&sr=1-17&refinements=p_n_feature_keywords_two_browse-bin:7306173011
Just fine for domestic runs.Hi guys
What do you guys think about this speaker wire
