Please help
Aylmerwolf
46
2
8
54
Hello everyone I’m new to marantz and I need help to plug my equipment does anyone know were I could get information
AV8805
MM8077
Klipsch speakers
Brand new
Well, there should be a QuickStart leaflet in with the AV8805 to get you started. After that (which includes connection to your display), there is an on-screen setup application accessible via the "Set-Up" button on the remote control.
Thanks Kal it helped a lot but now I have another problem I went true the steps but only plugged my 2 front speakers and my left speaker the tweeter doesn’t work so I tried another speaker in its place and it did the same thing???? I’m lost
You need to be more descriptive or, even, supply pix so we know what you did. How is the speaker wired to the amp (terminals at speaker)? Can you switch the L/R input cables from processor to amp?
Do the speakers have 4 binding posts or 2?
Reactions: NorthStar
You need to make sure the jumpers are installed between the two red binding posts, and between the two black binding posts.
Did you put the jumpers in for the speaker binding posts?
Shouldn’t be my problem the speaker works just not the tweeter on the left side
Well if the binding posts are connected but the tweeter isn't, then something is wrong inside the speaker.
Hm ok maybe you have an incorrect crossover setting in the receiver. As in they should be fullrange but maybe are set to bi-amp or low passed.
