The above driver is capable of close to 5 inches of travel peak to peak, has 45 mm of linear travel one way insuring low distortion as the coil stays in the gap. I have been in the room with and watched a Laptop screen display 3hz content at 110db from a calibrated microphone at seating level. The key to this driver is that it is designed for audiophile quality bass, and it does it in a 28" cube.
JL use to use the term "tight" in their ads and doing comparisons with it, the JL is tubby sounding. How is it possible to get accurate bass out of a driver this big? An 80lb magnet that provides exceptional control due to its high motor force. Some of you may have read the white paper by the king of subwoofer design Dan Wiggins that I have linked before on this forum. If you haven't, it's all about inductance, simple physics. Or go out and buy a 8" Klipsch ht woofer and listen to how boomy a small woofer can be, as it has a magnet the size of a rats testicle on it. When you put a kick drum hit into it, it acts like a spring taking 10 oscillations to come back to a rest. A driver must have very low inductance or it is going to sound boomy, simple physics. Here is the paper that everyone should read if they haven't to become educated on subwoofer driver design, and fast bass:
http://web.archive.org/web/20040403205713/http://www.adireaudio.com/tech_papers/woofer_speed.htm
QUOTE from it-
"It turns out that transient response of a woofer is not a function of the moving mass, as is commonly espoused (one of the most infamous audio myths). In actuality, it is based upon the inductance of the driver. And the greater the inductance, the slower the driver - the lower the transient response."
A 28" cube with a built in 4K watt amp, for $4K that will give you depth and ambience to all your recordings. The famous kick drum on James Newton-Howard/ Sheffield Lp, or Flim & the BB's will be one of the tightest you will experience. Most importantly is the large amount of airwaves that it can launch with the large surface area of the cone. There's no substitute for displacement when it comes to subwoofers. This driver has the equivalent displacement of (6) regular 18" HT subwoofers. Would you rather have 6 boxes, or just one?
