Is it possible that some of the distortions introduced by cables are similar to those of amps in terms of adding even/uneven harmonics? Extremely small amounts of added harmonics can change the sound character, see also these experiments by Bob Katz:
https://www.innerfidelity.com/content/katzs-corner-episode-25-adventures-distortion
Of course, harmonics are also frequency related, even though they may not show up in traditional frequency measurements.
Interesting bit from the article:
The changes introduced by cables are not measurable using standard analyzers and are orders of magnitude lower than those existing in any harmonic distortion studies carried so far. The only reference I have ever seen on this subject was an interview by Van den Hul, who referred to analyzers being able to dig in detail bellow -140 dB.
Unfortunately we can not mix cables with amplfiers in analysis - they are too different. Believe me - the knowledge about signal cables is based on empirical observation, scientifically cables are voodoo. Should we expect that the electrons of gold enhance the second harmonic?
This also flies in the face of claims that SS amps are a priori more neutral and transparent sounding than tube amps, and their reproduction comes 'closer to master tape'. Yes, there are colored sounding tube amps, but there are also colored sounding SS amps. even though the colorations of SS amps may have a very different character (c.f. above quote from the article). And there are quite neutral and transparent sounding tube amps just as there are quite neutral and transparent sounding SS amps (note that I use the adjective 'quite', there is no absolute neutrality or transparency).
We can always live on the exceptions, but my comments addressed the best or close to it of each class in the parameters we were addressing.
BTW, the article you refer is confusing, very limited - it refers just to headphone listening - and anything but conclusive. IMHO fun headphone stuff.
