Sorry to disappoint you, but WAV presented the best soundstage and imaging. The FLAC files also added a slight sibilance to vocals with 'S' words. That's when I realized that if FLAC playback was messing that up, it was probably messing other stuff up as well. It was an easy decision for me to Rip all my stuff to WAV. I don't give a flip about Meta Data... I listen to music!
Steve, which one is best, FLAC or WAV?
Let me guess which is the better quality...FLAC ?
Steve N. seems to prefer to optimize his digital systems by reducing the jitter going into the DAC as much as possible and then using a non-reclocking DAC. Others (most?) seem to have addressed the jitter "problem" over the years by developing/adopting reclocking DACs to get rid of as much jitter as possible which may have accumulated in the signal path, with the attack on jitter occurring right before the digital to analog conversion so as to avoid possible jitter injected by downstream cables, connectors, or electronics. While jitter may once have been a significant problem, according to testers such as Archimago (here) and John Atkinson (here) neither the Oppo UDP-205 nor the Benchmark DAC3 I'm using have significant problems rejecting jitter. Benchmark's own published jitter immunity results show its DAC3 to be quite immune to upstream jitter. See Graphs 15 and 16 on pages 61 and 62 of the manual here.
How about .aif files?![]()
WAV is the best of all the formats, including FLAC, uncompressed FLAC, AIFF, and ALAC.
Steve N.
Empirical Audio
Now, do I need to re-rip to WAV, or can I just convert all the FLAC files to WAV and have the same excellent sound?
You need to start over and Rip them directly to WAV files!
Further listening has convinced me that compared to CD playback from my Oppo UDP-205 through the Benchmark DAC3 HGC, the uncompressed FLAC files on the USB stick inserted into the Oppo's USB slots are not as good sounding. Less depth of field, less certainty of image placement, less instrumental detail, a bit of screech on strings, a bit of dynamic compression, and a general feeling of less natural and relaxed presentation which leads to boring listening.
Given Steve N's proclamation of WAV as the best sounding files, I re-ripped a couple of CDs to WAV and compared those to the CDs. The WAV files sound excellent when played back from the same USB stick on which the FLAC files sound second best. The WAV files sound fully the equal of the CD playback.
The culprit is NOT the format (FLAC) but the obvioiusly poorly implemented USB section of the Oppo.
- Owen Smith (Quora)"The Free Lossless Audio Codec (FLAC) is the most popular lossless format, making it a good choice if you want to store your music in lossless. Unlike WAV and AIFF, it's been compressed, so it takes up a lot less space. However, it's still a lossless format, which means the audio quality is still the same as the original source, so it's much better for listening than WAV and AIFF. It's also free and open source, which is handy if you're into that sort of thing.
The WAV file is one of the simplest and oldest digital Hi-Res audio formats. It was originally developed by Microsoft and IBM in 1991. I'm not going to go deep into history, but, in a nutshell, Apple later derived its own version of WAV, and they called it AIFF (Audio Interchange File Format). Basically, AIFFs are Apple's equivalents to WAV files. These audio formats work by taking audio signals and converting them to binary data.
Actually both of these audio formats have their advantages and disadvantages. I prefer using FLAC. Because it has the original quality, even after compression. If you want to convert WAV to FLAC or convert FLAC to WAV, you can use a video converter tool."
