After Windows 10 upgrade.....
lamiler
5
35
I wonder if the login password will be changed after the upgrade ? i have Checked caps lock and the keyboard layout, there is not issues with it , but my correct password didn't work on computer .
What should i do now ?
we can issue you a temporary password that you can change once logged in BUT if you are posting now you must have used your password
I am still trying to understand how you logged in if your password doesn't work
I am using my friend's computer at her home now ,my computer doesn't work because passwords aren't accepted .
You know , you can reset the password after log into your Microsoft account .
