Hello david
The original Everest system had a shelved response in the last octave by design and was not in anyway flat into the 30's. It was flat to about 40Hz or so. In the design paper they discuss this and recommended a sub if you wanted response to 25Hz. You can't expect 98-100 Db woofers with light cones to have solid bass down to say 30 Hz or below. You need mass and with that you sacrifice efficiency. The current system is also rolled off in the 20-30Hz region. None of these systems either modern JBL or vintage Altec, JBL or the Folded Horn systems like a Khorn can do the 20-40 octave justice compared to a modern subwoofer system. You need specialized drivers or horn designs like Danley's to get that first octave. I use sub's to augment my main system and my Arrays are good to about 25Hz but they sacrifice efficiency of bandwidth.
Rob![]()
My Klangfilms go down to 50hz and then there's a sharp drop off from there. I supplement them with subs down to 30's these days but in reality 50hz horn bass is plenty. How many speakers have ruler flat in room performance even today that can also play real music? I know you can measure test tones from digital subs but that's all they're good for IMO.
david
