Maybe the kids are all right...
cjfrbw
1,520
1,760
Pleasanton, CA
Played some 128KBS MP3/AAC from my Mac Mini analog headphone outputs to my main system.
Mac Mini analog output TO: Allnic L 5000 DHT preamp: OUT TO main system.
It sounded really good. Bill Laswell "Shinotech Iridescence" and "Tumo" recorded from iTunes internet radio.
Am I going crazy?
Am I going crazy?
It's the preamp!
Nope. Not crazy. 256 kbps is even better. 320? Very few can tell the difference between 320 and CD. The analog out from the Mac is the biggest challenge, but honestly?...they're pretty quiet.
Tim
No your not crazy. The devils in the details it's the low level stuff that gets lost or has artifacts. Try using VBR when you encode just set up for a higher data rate and best quality. I use 256K VBR and it sounds very good. You get a smaller file size and you use the bits when you need them.
Rob:)
I wonder if it is a matter of the bit rate or of multi-tasking that keeps young people from appreciating well recorded music. You see younger people doing 5 things at once, and I ma sure none of them well.
