Was just looking @ my GG2
it has KR PX4s and a KR 5G4U 2016 Lampi SE, not PSVANE PX4 as I said earlier.
Wow that’s complex can you try the usb right out of your sever and comment please
Sorry but I´m so sure the USB out of my music computer will sound even worse that I don´t want to go there. LAN rules!
Wow a loaded deck comment ok then carry on
Interesting information indeed.
Are direct from your server. Or to an ethernet switch? Do you use high end ether cable?
Thx
Hi jturbo!
I did write some of that today at 4:44 (not my local time): Aquvox AQ-SWITCH SE.
http://www.myhifishop.de/Devices/AQ...h-End-Network-Switch-audio-LAN-isola::87.html
There is a TP-Link fibreglass connection in between the router and the switch for galvanic isolation.
The LAN cable out of the Aquvox is the top of the line Aquvox (which I didn´t find in their online shop right now). The other LAN cables are "Supra Cables Cat 8 STP Patch network cable 2000MHz Ethernet>40Gb OFC" from eBay.
Hth
Charlie
Thanks, I missed the switch info when reading your earlier post.
Are you using a single ethernet port on the roon server for control/streaming and playback towards the lampi?
If the server has an internet/control facing ethernet port and a second port towards the DAC ... Im wondering if maybe a dedicated ethernet connection between the roon server and Lampi would be best? I guess maybe im wondering if the switch between the server & DAC is beneficial in some way.
Thanks!
The EMO devices are quite well known on Computer Audiophile, especially the EN-70 model. Acoustic revive / Baaske / Giso / SoTm also offer similar galvanic isolation transformers.
