Agree with you Tang. The Allnic range are very sensitive to microphonics (although I did not test the 5000) despite their fancy tube socket.
Does power supply get any benefit from anti-vibe?
Peter, Tang may not get the full fat Stacore effect sans pneumatic isolation to his AS, but the rack/shelves will still have uber mass loading, Stacore constrained layer tech, and isolation built into the legs/supports.
Otherwise what would have the point been to order this bespoke unit, Tang could just as easily purchased Dave's preferred option.
Hi Tang,
Yes very much so. If you have any tube power supplies not getting benefits from your racks, try it out. You’ll be happily rewarded.
(...) Active isolation would be welcome with amps....or any inanimate stereo component that doesn't fight the active isolation like spinning TT's do, ime.
Jarek, if Tang is getting the Stacore uptick on his AS that I'm getting on my Salvation, he's in for a continued treat.
Your Advanced has so transformed my tt, that I consider it non installed/broken before.
Finally I'm getting analog going to places my highly respectable cdp can't reach.
This was never the case pre-Stacore.
I can not see how a spinning turntable fights the active isolation intrinsically, but I am prepared to learn.
It's easy to see and the Herzan vibration graph shows it. When a TT spins it creates centrifugal forces in the form of vibration that drain out it's chassis. The Herzan will in turn try to counteract that those forces/vibrations that it is sensing. It will inject itself into the vibration feedback loop that all TT's have. IMO and experience, it's counterproductive with TT's. YMMV
I hope your new “nothing” rack isn’t one piece. Otherwise you would need a forklift running into your house.
Are the legs in cylinder or square?
Tang
Thanks . IMHO a platter spinning at uniform speed will only create centrifugal force if it is poorly balanced - a high quality turntables such as yours do not suffer from this problem. And as far as I could understand the AS2000 does not have feedback in its motor speed control - the measuring device is purely an indicator.
Are you saying that when the platter turns the Hertzan platform detects periodic motion?
There is a feedback loop between platter, plinth, bearing (if applicable), tonearm and cart. It flows in both directions. The way to get better results with active and I experienced this with my AF1 is to isolate/buffer the TT from the Herzan top plate (HRS shelf in my case). That way vibrations coming from the TT are somewhat isolated from the herzan, resulting in less active isolation opposing forces (interference) being injected in the mix. Floor born vibrations are the only vibrations I want being attenuated with TT's....Not the vibrations/forces created by the TT itself. With the AS2000 sitting directly on the metal plate, any vibration that is created from the motor and or platter is attenuated. The result is a deadened sound lacking life and sparkle.
Thanks . IMHO a platter spinning at uniform speed will only create centrifugal force if it is not balanced - a high quality turntables such as yours does not suffer from this problem. And as far as I could understand the AS2000 does not have feedback in its motor speed control - the measuring device is purely an indicator.
