Astrostar, I am glad you like your Kassandra. I respect that. Are you a dealer or distributor of Aries Kassandra?
Oh my, now it gets personal. I am an owner, not a dealer or distributor. Are you?
Hi Thieliste,
hard to answer if 10k worth the investment !. i'm an owner of Seven with server & USB Gigafilter and i Know, also very well the Twelve so yes there is a difference but the Seven is a onebox dac world reference which has the most DNA of Twelve. And notice that a Seven can always be upgraded to Twelve !!!
I'm french guy too and since 8 months i'm the really lucky owner of the kind of Totaldac system you listened in Paris or in Berlin next year, with d1-Server/Seven, Absolare signature amp and the d150 Totaldac speakers + sub... and the musical result is just stunning !
Be well in music
I would pitch the Kassandra Ref II against the twelve TBH. The gain stage in the Kassandra is one of the many things that takes it to a higher level. It is more dynamic and solid / fuller than the Twelve, more body but still super smooth and with a fantastic timbre. I would try and get to hear it if possible before you drop 30K on the twelve.![]()
The SE version of the Twelve has a gain stage that is quite exemplary from what I have heard from Vincent, but I cannot comment on its sound personally. The Twelve omitting the extra gain stage is special in its own right. It is hard to beat it for transparency when using a good preamp. I encourage anyone to hear the Twelve in their system. It is a big improvement over the Six.
Agree!
Six cannot come close to the Twelve, and not even a Seven can do so as well.
I guess the gain stage of Seven may be tickled-down from that of Twelve SE?
BTW I have carefully listened to Twelve SE twice, comparing kicking on & off its gain stage.
I personally like the sound without the gain stage more. It's so effortless and real!
I would rather use a good preamp like the Ypsilon PST-100 Mk2 therefore no need for the SE version.
Agree!
Do you have have a reclocker option in your Seven - d1 server combo ?
I have a two-box source and the d1-server get a reclocker inside.
The d1-seven is a very serious improvment of the d1-six, so it approaches naturally more the Twelve but obviously without reaching all that kind of magic proper to its constructions but don't forget, one more time, this is another of the great qualities of these devices, the seven and all totaldacs can be upgraded to the d1-twelve !
Only Vincent can answer about the Seven and the D1 Driver at this time. I do not know anybody else that has the Driver. I do not have the SE version of the Twelve. Just the Twelve, and I have no desire to try the SE version.I like the Twelve with my preamp.
I would like more info about the 5 in one chassis power supply!
Hello Paul79,
I got my Totaldac Twelve SE (I prefer without the output stage) late 2017 with the 5 output power supply. I find it very convenient that I had to purchase only one power cable. I did not compare it with 5 separate small boxes, but I suppose they have the same quality otherwise Vincent wouldn't do it. Having the one-box power supply also saves space and allows me to put it on my SRA Scuttle mk.3 rack, which makes a difference.
https://systems.audiogon.com/systems/795
Cheers,
VPN
Hello CKKeung,
Thank you very much! I enjoy reading your posts and advice!
My next upgrades will be:
a) Two Kubala Realization power cords for my Krell 750mcx monoblocks. I should have them this week.
b) Upgrade my Totaldac Twelve AES-EBU cables from Kubala Elation to Echole Omnia.
c) The Totaldac Server is composed of a minimalistic server that connects to a reclocker located in the same box through an USB cable (I am using the Totaldac Gigafilter USB cable). The The Server reclocker output then connects to the Totaldac Twelve DAC through an AES-EBU cable. After I get the Echole Omnia AES-EBU cables I will decide if I prefer: (a) The USB output of the Totaldac Server internal server, so using the Innuos SE as a NAS (I use the Totaldac Ethernet cable) or (b) The USB output of the Innuos SE entering the Totaldac Server USB input of its internal reclocker. If I prefer (b), then the Innuos Statement may make sense (or perhaps the upgraded SGM server that will be released). If I prefer (a) and use the Innuos only as NAS, I will probably keep the Innuos SE since the upgrades to the Innuos Statement USB board would not be used.
Cheers,
VPN
