Sure.
david
I think this is a good idea if others are interested... Seems folks have questions about what X, Y and Z sound like and I'd be more than happy to send around a couple of cable for people to try and hear for themselves.
Sure.
david
I think DaveC feels pretty strongly that his silver and silver/gold wires exhibit higher resolution than copper.
What say you, DaveC?
There's no doubt about it.
But silver isn't silver... you can't generalize as I said before. It HAS to be UPOCC silver. All other silver wires are inferior vs UPOCC silver by a large margin. Typical 4N silver wire has many issues as others have mentioned. It can sound harsh, introduce glare, and accentuate the leading edges of notes which is the main form of "artificial detail" that people often think sounds good at first.
UPOCC silver has NONE of these downsides. The one downside it has is thin tone. This is solved in one of two ways. 1. Increase the gauge. This is what Wireworld and Siltech do with their top of the line cables. 17g runs for IC cables, so... they can easily double as SCs if needed.And it's part of why they cost a lot. 2. Add gold as an alloying element. I do this and it provides a warmth that does not decrease resolution. This makes this wire a sort of unicorn, it has very high resolution with good warmth, extremely realistic timbre and no harshness, glare, etc...
I've played with wire for well over 20 years never being satisfied. I've tried many different kinds of silver and copper wire, I've tried combining them, I've use teflon, cotton, air-tubes, nitrogen-filled air-tubes, you name it... Nothing comes close to the OCC silver/gold alloy I have custom made for my cables. This is why well over 90% of people who try my IC cables buy them.
. . . My cables are alloy too.
There are other problems with silver, colored bass and softening and homogenizing of transients.
david
These things cannot be generalized. Just like the ultra-pure copper, there is silver and then there is silver. The purity, surface finish, and metallurgy all make a huge difference. Many manufacturers don't pay attention to all three and their cables suffer.
Steve N.
Empirical Audio
Yes Ron. I beta tested the first formulation, then came two more then finally the production version. While geometries and dielectrics were basically the same, these were four different metal mixes tried in total. B was too fast, A and C touch too pretty, nice color but too colored. The final one balanced extension and tone best. Loads of spatial cues without having images too razor sharp. I believe the new Signatures are alloyed too but Leif should confirm that. It's funny really. While I shuttle between my two temp systems here, the Ultra XLRs shuttle along with me. LOL.
What is wrong with having imaging laser-sharp? Seems more live to me.
Steve N.
Empirical Audio
Steve N.
Empirical Audio
I do not hear in the concert hall the razor-sharp, clearly-delineated images we sometimes prize on our stereo systems.
Very interesting, Jack.
Do you find the original copper conductor Signature line to have a warmer tonal balance than the Ultra?
Shouldn't the presentation depend on the recording? Some studio recordings do produce "sharp" images and some live recordings have a more diffuse soundstage. If your system takes a studio recording with clearly defined images and blurs them that's not good. I'm not sure the opposite is possible but if it were I wouldn't want that either.
It's pretty clear to me the closer the system gets to reproducing what's on the recording the better off you are. This can be worked toward in a more systematic and objective way vs trying to make your system how you imagine live music is supposed to sound, which may be influenced by many undesirable things anyways. I'm not saying there's no room for personal preference but a focus on achieving "high fidelity" is also important imo. If high fidelity means sharp images, so be it. I can make a circuit that would dump a ton of warmth and fuzziness into the mix very easily for those who want that...![]()
Most certainly however I don't think I've actually come across a recording in any genre, including test recordings where "razor sharp" seemed to be a priority of the artists and production team. Movie SFX yes, music not so much. I would like to have some in my library. Recommendations would be very illustrative and thus much appreciated.
Ok... There's one Boards of Canada track where they create this soundscape and parts keep getting added and they all line up in front of you. I think off the top of my head it's Chromakey Dreamcoat but I'll have to listen to be sure. edit: It's not that one.. it's a fun track though. I'll have to listen and see if I can find it.
Beats Antique's newer album Contraption II is pretty good. Beats in general is produced well, and sounds best played very loud.
IMO lots of electronica is carefully produced and has well defined images. Boards is more ethereal in general, not always a great example of precise imaging, but Infected Mushroom, Opiou, Tosca, Amon Tobin are worth checking out if you haven't already.
But my point really is that faithfulness to the recording is an important goal, and this faithfulness may include hearing well defined images in recordings that contain them.
Not for me. An example where it can be overbearing, again for me, are overdriven guitar amps. While I like solid images, I prefer outlines to have gradients. Not dull or soft mind you but rather varying in texture as timbre dictates.
