On your dac, have you tried rolling the EML Lampi special 45s and the KR 242s?
If you can ever get a chance, would like to know how GE 211 compares to the KR 211 tube
I haven't done any tube rolling on the Golden Gate. On the recommendation of a GG owner who auditioned a wide range of tubes on the GG, I went with his recommendation which was the KR-Labs 5U4G rectifier and a quad of KR-Labs PX4 output tubes.
I've posted this elsewhere on the forums, but I highly recommend a complement of Herbies Audo Lab tube dampers. I use three differently sized damping rings on the 5U4G, one on the top "nose", one on the shoulder, and one on the base. For each of the PX4, one on the shoulder and one one on the base. I found that I needed an additional fourth contact disk for the shoulder placements to prevent the ring from gradually slipping either up or down.
I also added a 1" soft support cup (black), flat on one end and concave on the other, on top of each tube. These are also from Herbies and are designed to hold a round ball on top for a component support. I put the concave end contacting the top of the tube and placed a 3" heavy damping disk on the flat end. You have to be careful since the cups and weighted disks are only held in place by gravity, so be careful to keep them centered. You might want to use a dab of silicone glue between the flat end of the cup and the damping disk as a safety measure.
The damping system really helps the GG. I didn't realize how much the vibrations of the tube envelopes impacted its performance. The result is a quieter noise floor, better soundstage, but with no loss of top end air and openness. All the good stuff is still there.
These are the sizes of the damping rings I use.
5U4G -- (top) Rx50, (shoulder) Rx65, (base) Rx35
PX4 (each) -- (shoulder) Rx55, (base) Rx35
Best,
Robert
...keep in mind that sources of tube vibrations include that from the device itself (a DAC in this case) as well as airborne. So...recommend using the tube dampers from Herbies Audio Lab.
...over the years I've used various tube damping products...The worst...that I've tried are the typical thick damping rings that you slide over the tube...causing a smearing of the sound. For the life of me, I don't understand why large "high end" companies like ARC still use those things (I owned an ARC REF3)...
Best,
Robert
KR 242 are very preamp impedance and system gain dependent.
Mariusz, I forget, did you try PX25 and the special 45s?
As far as PX 25 are concerned Lukasz advised me not to go because they have higher gain then PX4.
I had also some EML special Lampi edition ,hardly remember the model, did not like it.
I must have somewhere a picture, If you want I will check it for you.
Ron, no I haven't used active isolation platforms. Though they may provide benefit, keep in mind that sources of tube vibrations include that from the device itself (a DAC in this case) as well as airborne. So, I would still recommend using the tube dampers from Herbies Audio Lab.
One point, over they years I've used various tube damping products. I've found the damping rings from Herbies Audio Lab to be superior. The devices have a very small contact area with the tube via three or four small disks with very small elastomeric rings on perimeter of the disks that actually contact the tube. There is very little vibrational energy transferred from the tube. Think of it as analogous to damping the vibration using your hand, touching the tube with just three fingers.
The worst damping devices that I've tried are the typical thick damping rings that you slide over the tube. These tend to store vibrational energy and then release it back into the tube. This returned energy is delayed and is out of sync with the original, causing a smearing of the sound. For the life of me, I don't understand why large "high end" companies like ARC still use those things (I owned an ARC REF3).
Best,
Robert
Audiopax Model 88...
I second that.
I wondered why they wasn't mentioned in the first post. They are made to rock the horns.
The impedance of the ribbon driver is suggested by Brad to be a fairly flat and relatively easy to drive 6ohm load with 89dB sensitivity.
