Where do you place your equipment???
Loheswaran
470
123
348
Out of interest where do you place your system?
At most shows, you almost always have the equipment between and behind the speakers. Against this I have read, that you are better off having your system set up to the side as it is less affected by feedback acoustics etc...
Anyway please let me know what your findings are
for myself, my gear is mid-wall along the side. only speakers and amplifiers in front.
I would say that feedback is similar objectively both between the speakers and along the side, individual specific situations differ from each other. feedback can almost always be neutralized with reasonable effort. so it's fixable.
OTOH acoustics are clearly better when the gear is not between the speakers; and this is almost always the case. and the higher the resolution and dynamics of the system the more significant this would be. and really you cannot eliminate the acoustical consequences of gear between the speakers. you can learn to live with it. and it's not a make or break type thing in system performance.
Reactions: Lagonda
I think the ideal location for source equipment and preamplifiers is in a separate, but adjacent, room. This does not reduce foundation-borne vibration but it reduces acoustic feedback.
In a small one bedroom apartment I lived in years ago I had the speakers and amplifiers in the living room, and I located the turntable and pre-amplifier in a separate, fully closeable, walk-in closet near the living room. (I though that was a pretty deluxe set-up for a one bedroom apartment.)
Hi Mike - and Ron
I am getting a loft based 'man-cave' - can't wait - my own dedicated 'room within a room' - alas I can't have my equipment in another room Ron
I have my equipment at the side at present and was wondering if I should move it back in between for my future room - my idea was, in part, to save money on speaker cables a tad - that said acoustics are the main issue
Hi Mike - and Ron
congrats on your 'own space'. that can make such a difference with listening pleasure in just getting comfortable with a dedicated space, even if it's within a larger space.
I'd say that the acoustical consequence is minimal, but not nothing....unless there is a video screen or window included. so where the gear is would be way down the list of concerns. maybe better shorter speaker cables might be more of a performance boost than longer lesser speaker cables but gear on the side.
enjoy 'your' space!
I think having the source equipment and pre-amplifer on the side is preferable to having them between the speakers. You may even get a rare, strong consensus on this.
I have my system sitting in my L-shape office. My speakers and amps are at the top of L while the rest of the system is on the right leg of L. So the sources never get directly fired by the speakers. But it poses other challenges to overcome since my right leg of L is another 5x3 meters. I cant get the sound to envelope me like a normal rectangular room. I decided to use horns to project sound at my listening position to lessen the effect of my room. Many more compromises I have to accepted because it is really not a dedicated listening room.
Kind regards,
Tang
Or behind, for the sources:
And with the amplification up front, near the loudspeakers:
Reactions: Sharp 1080
I think positioning the turntable between the speakers or near the speakers is not the best position. ...Near the listening position is better.
In many setups though we see the TT between the speakers; it has more chance of getting the speakers feedback into the pickup of the cart.
Question: Is there any benefit to suspend the turntable's shelf from the ceiling with four chains?
I just place my equipment on a rack and the rack is placed anywhere convenient. When I run out of rack space, The power amp(s) are moved out and placed near the speakers.
My sources, preamp and other components are about 10 feet behind where I sit.
My speakers, crossovers and power amps are 20 feet in front of me.
Interconnects extend from the preamp through holes in the floor, into the basement and back up to the amplifiers.
. . . . Question: Is there any benefit to suspend the turntable's shelf from the ceiling with four chains?
How about in an evacuated chamber, mounted on a very heavy granite slab, floating in a tank filled with mercury? ? ? ?
:D :D :D :D
Reactions: the sound of Tao
This is one of the best looking rooms I've seen anywhere. Someone should have told his installer however that to keep cover fabrics from sagging they should be installed with the room as cold as possible. :)
For me at this time, my house determines my setup, which is between the speakers.
Sorry for the OT there
I keep everything except amps and speakers to the left side of my listening room. They are nestled between resonator traps to the sides and a broadband absorber above. All false rigid/reflective walls in my room also serve as sealed pressure traps.
I chose this as the best compromise. I've found that long ICs given properly matching electronics are easier to deal with than really long speaker cables. Less expensive, sounds better. No brainer IMO. I also like having more control of the front wall acoustics, something racks front and center make much more limiting.
If all I did was stream or listen to files, all I'd have inside my room would be the amps, speakers and a tablet LOL. I refuse to miss the first few bars of any song so you won't see me putting my turntable more than 10 ft from my listening chair.
It has a little of that asylum room feel, just a little.
...Only the acoustic panels on the side walls.
Very true; having the TT between the speakers you miss the first few seconds before you can settle comfortably in your lounge chair.
About having the TT right beside the main listening chair, @ seating level?
I've never seen that though, but I thought often about it.
* I was searching around the world wide Web, without much lock.
This is the closest I came to:
