Somebody prove to me I am wrong....Don't think so Roger
Otherwise why do so many AE owners have 2, even 3 Troys?
The capacity of any Tripoint should be unlimited as far as grounding multiple components. The only limitation is the users ability to configure the connection. There is no hocus pocus here,the connection to mains ground is sufficient.
Do not think so. The Troy seems to be much more than just a distribution box.
If you're right Roger, Troy customers REALLY have cash to burn, or sales advice is less than correct
A Troy Elite w 3 Master Ref grnd cbls per post should work according to you
Micro,same concept,same result.
What is the concept of Tripoint according to your opinion?
Well the key I believe is the result...chassis grounding. More clarity,dynamics,separation,tonal purity,nuance,expanded soundstage,closer to the recording event...same,same.
The Tripoint is connected to the component and by a modified PC to mains ground,that is all that is needed. I will say no more.As far as I know, it is not chassis grounding. The ground points of the Tripoint and the mains ground are not connected through low resistance straps. It is why I asked for how we should use them.
Congratulations Mike. Have read lots of raving comments on Troy Elite from Asia but it will be even more interesting to read your comments. Don't keep us in suspense too long.just found out that Miguel will be shipping me a new Tripoint Troy Elite next week. I'm excited to replace my Troy Signature on my sources with the Elite. then the Troy Sig will be moved to my dart mono blocks for chassis grounding. i
I would not presume to get into technical merits of the Tripoint products. not only is my knowledge limited to understand it, but I don't really care about it at all.
I can only say that in my system the Tripoint is purely used in a 'chassis ground' situation. and that the Tripoint Troy Signature itself is connected to the wall outlet with a plug with disconnected hot and negative pins. only the ground pin is connected to the Tripoint itself. so it is connected to the power grid ground.
I hope that is helpful.
Mike,
A device used purely on a "chassis ground" situation would not depend on connecting cable material for example. Miguel Alvarez is quite clear when less expensive cables are used, even thicker - according to him, the “magic was lost.” So he must use expensive solid silver cables. Troy is much more than just a grounding strap.
My only question is on the use of the three Cardas connectors of the Troy - can they be used indifferently, or we should group equipment according to a preferred scheme?
If you use mono power amps, Miguel suggests not to connect both sides to the same Troy connector. Also, never connect line stage and phono stage on the same connector, same goes for digital transport and D/A converter. I did not test those "rules" but others have...My only question is on the use of the three Cardas connectors of the Troy - can they be used indifferently, or we should group equipment according to a preferred scheme?
Mike,
I have found in my own system many years ago that if I mixed different cables on the same post, things got funny...a bit fuzzy. If i keep the same kind of cables and uses (ie, grounding signal vs grounding chassis) on separate posts, then all good. I have 14 connections to 3 posts...last time i spoke with Miguel he said that was a record!
thanks guys. that sort of user feedback is very helpful to me going forward.
