Hopefully this helps:
https://www.google.com/search?q=composting+techniques&ie=utf-8&oe=utf-8
Really though, proper decay wrt the system and not the room is a result of resolution of detail. A system with good resolution shouldn't truncate the decay of notes, reverb trails and spatial information.
Personally, the best decay I have experienced is from an (omni-directional, all solid state) MBL system in a room with SMT diffusers and Helmholtz resonators...
Other than the "perfect room", how does one get more decay?
Thank you
you need a room that is 'live' but tame. you need enough live surfaces to retain the musical energy, yet reflective glare has to be controlled so the glare does not obscure the decay.
there is no right and wrong.
I think it was the RE Steve Hoffman that did a experiment on decay with a analog vs a digital recording and the digital truncated the note more than the analog recording. My answer would be to increase the signal purity of the playback system. No reason digital can't do as well.
Certainly not. If it were low distortion then the issue would have been solved.
Certainly,your digital experience is not the same as mine. Don't feel bad though you've got a lot of company including Steve Hoffman whole is overrated. When RE's like Tom Fine move to digital,I take notice.
You can also stop flossing and going to the dentist for a cleaning.
Does anyone have a sense of humor on this forum?
Guess not.
Very sad IMO.
Guess not.
Very sad IMO.
