Mike
I'm making arrangements for you to demo the MB ULTRA. IMHO you'll know the difference 10/10 blinded. Im home on Tuesday. When you're done I'll see if I can send it to Priaptor because quite honestly this cable belongs in your system. I have zero desires to go Ethernet since I've put this cable in my system.
Hi Mike, I've noticed, that you currently do not have a cd transport in your arsenal. Maybe, it was mentioned before, have your had a chance to compare a good quality cd transport to the SGM in your system?
Thanks,
Aziz
Thanks, Mike.
I have read many posts on different forums claiming, that no file transport can compare to a sota CD transport soundwise. Personally I do not believe this is to be the case, and your experience confirms this. In any case, taking into account a relatively large number of available quality DSD content and Tidal, limiting yourself just to CD playback nowadays simply is not practical in my view.
Aziz
(...) getting back to higher rez, both PCM and dsd, the best of these take things clearly to a level transports cannot reach in certain ways.....particularly space, note decay, ease, authority, and delicate texture and complex layering of music. this is based on my experience up till now, we will see how it plays out.
Hi Mike.Aziz,
I did have the Aqua La Diva CD transport (now sold) until a few weeks ago, to go along with the Formula dac. it was very good (but not quite as good as the SGM) but it's i2S interface is not compatible with the Select II.
when I did compare the Aqua transport and the SGM, at first it was very close, with the SGM ahead by a hair. then there were software advances with HQ Player which pushed the SGM clearly to another level.
MSB would like for me to try one of their transports once I've settled on whether I will be staying with server/usb or switching to the new Ethernet renderer. so I will be going down the transport road again. MSB thinks the transport still has advantages.
we will see.
Hi Mike.
I am using the D1 from CH Precision and to my ears the transport outperforms the Aurender N10 when I listen to the same CD`s ripped to the Aurender. I am also using the CH Link cable between the C1 dac and the D1 and that might contribute to what I hear as well. A good transport (I am sure that the MSB is right up there with the D1) in your system will definetly sound very good and I think that you are in for a very good listening experience. Well worth trying!
JP
My D1 also plays SACD and that pushes the sound to an even higher level. All this said, the Aurender N10 is a very fine product and I am very happy with its sound.
That does not surprise me at this point. Could you please gives us some details as to what you think the transport does better?
Thanks for your reply. Interesting what you say about more "body"; this is what others have reported for the dCS Vivaldi when using its transport as well. If you have an option other than a USB connection for the server, that is certainly worth trying.
Aziz,
agree; my gut tells me that even ignoring higher rez files for a moment, that files have a higher upside than a cd/sacd transport.
OTOH as I listen to this MSB Select II, it is hard to discount anything MSB tells me. they have broken the code on digital performance......and so I will follow them down the transport path and keep my mind open. they are working on next level transports.
Hi Mike,
Having played numerous red book CDs and SACDs through MSB's Universal Transport and Select II DAC at Axpona, I would say they cracked the code on this transport too. The secret sauce on the Universal Transport is its proprietary I2S connection, which allows the digital data to be pulled and clocked by the DAC rather than pushed by the transport. The result is one of the best sounding transports I've ever heard. No reason for a newer and more expensive MSB transport IMHO, although slight improvement might be gained by superior clamping. The MSB Universal Transport is a terrific component and a tremendous deal at its current price point. Really no need to venture any further.
Best,
Ken
Peter from Audio Note explains why a transport is superior to ANY server setup. They make a transport that costs over 100,000. This is a very interesting video. I have talked to there dealer in California and he has had people bringing in there computer and separate servers and hooked them up and compared to a transport. He has said every person was flabbergasted because they all said they are just zeros and ones. Very clear difference to all. MBL has that connect between the transport and DAC which is key. Audio Note also has a special connection between the transport and DAC. https://www.youtube.com/watch?v=BijKabByrZQ
(...) I can only imagine how good the Audio Note Fifth Element sounds. I wonder if any have been sold, or is it an icon product, i.e. what we can do when no budget constraints apply?
Unfortunately IMHO he does not explain at all - he just talks about the "fragility of digital" - a subjective concept. As far as I know no one has ever explained why the spinning CD sounds better than files. Even manufacturers of excellent sounding transports end up saying they do not have a reason, although it really sounds better.
