If u are using mono amps 3 lines....
Ok so you will have 2 duplexes or 4 outlets. plug each mono block into a opposing duplex and use the remaining 2 outlets for your preamp and a multiple power strip or conditioner. Use Romex 10 for your wire.I have mono blocks,and can work with 2 lines only.
one of them for the amps .
what is the minimum thickness of the wires from the breaker box?
btw,230V here.
What country?I have mono blocks,and can work with 2 lines only.
btw,230V here.
In a typical 120V hi-fi system, I would go with one 20 Amp circuit. Using one size larger cable from the main breaker box to the wall outlets.
In a large system, I would run a feeder from the main breaker box to a small breaker box near the equipment, then as many 20A circuits as needed.
If a star ground system, uses more Safety Ground wire than the Hot or Neutral, then you did it wrong.
The Safety Ground/Protective Earth wire should run in very close proximity to the Hot & Neutral wires back to the main breaker box. (panel board)
If connecting it to a water pipe changes something, than have a good electrician look for problems (maybe a lost Neutral connection).
