Tripoint troy signature grounding device
Mike, I just went through your system and found we only have one common component, the Tripoint Troy Signature. What grounding cables do you use?
well, I use a number of them in various places (my audiogon system info is now 18+ months behind).
on the Tripoint Troy Signature for chassis grounding I use the Thor Reference on the darTZeel preamp, then I have the standard Tripoint grounding cables to (1) dac (2) server (3) power supply of tt and (4) armboard of tt.
then I have the Entreq Silver Tellus for signal path grounding I use a pair of Atlantis Eartha RCA's to unused RCA inputs on the dart pre, then a pair of Apollo Eartha RCA's to unused RCA outputs on my dac.
over on the amp end, I have an Entreq Poseidon with a pair of Atlantis Eartha spades to the negative speaker terminals on my dart 458 mono blocks. since the Poseidon has three independent sections, I then use the middle one for grounding my plate amps on my MM7 bass towers. for runs to each of those towers I use base level 4 meter copper spades, then near the towers I connect those spades to Tara Labs grounding cables with special Tara Labs 'keys' that tap into the plate amp chassis (2 per tower).
in addition to the Poseidon, I have three small Atlantis Minimus boxes which 'supercharge' each section of the Poseidon; these come with short silver spade cables.
aren't you glad you asked? :D
i know that if i were to want to take things further, one way to do it would be to substitute those standard Tripoint cables for more Thor's (or even higher level Tripoint grounding cables).
I'm happy with my overall grounding scheme, and think I've taken things quite a ways forward with it. my next 'tweak' money will more likely be involving further resonance treatments (stay tuned for that), not more grounding efforts. but i know i can do more with grounding when it's turn at the money tree comes again.
Just to clarify, Dalby Audio supply products direct in Europe and USA. Or through Audioexotics if you reside in the far east.
Kindest Regards
Lee Dalby
Welcome to the forum Lee
Dear Mr. dalby,
Your RitzCarlton cable is really something.
Kind regards,
tang
Hello there Mike, hello Gavin.
Just purely from an audioporn perspective, I don't suppose you have any pics available of the Jundo i/c's would you?
Hello Tang and thank you for your kind words.
Do you mean our Jundo Class cables?
Kindest Regards,
Lee Dalby
Hi, David.
We are currently working on the Parousia, we have been since 2012. We would like to have units available by next spring but we shall see.
Kindest Regards,
Lee Paul Dalby
Hi, David.
Kindest Regards,
Lee Paul Dalby
Looking forward to it Lee!
david
My head is banged up alright. I just bought two more Dalby wires. :p:p:p
Hello Tango,
Audioexotics will organize their 5th AE Super Hi End Show in Hong Kong on 8th-9th July.
Will your agent or you attend the Show? Mr Lee Dalby was there last year.
Cheers,
CK
Good effort Tang!
Which ones did you go for?
Hello Tango,
Cheers,
CK
Sawasdee CK,
I wont be attending the show. Maybe my agent would. I would be motivated to go if they have something that interest me but as of now nothing just yet. For me, AE attracted me with their grounding devices and also clean power devices. Their grounding things work very well in my system. However, their power cleaning devices didnt lift the performance of my systems.
I have the Dalby Celestial for half a month now. It makes me happy enough I dont want to try the Thor and buy two more. I heard AE will be presenting the new Troy Elite in the show. But at this point, I am done with grounding.
Best regards,
Tang
