Richard Mille RM50-03
Like the Magico speakers, it also uses graphene reinforced carbon fibre. So if you want a watch that will go well with Magico speaker - well, this is it. $1.000.000 in retail.
http://www.ablogtowatch.com/richard-mille-rm-50-03-mclaren-f1-watch/
BTW - there is a great explanation of this tech on McLaren (the F1 car manufacturer, who have developed the watch case for RM) site:
Can you simply explain nanoplatelet reinforcement?
“Yes, graphene is infused or mixed into resin systems, and those resin systems, for the application of creating carbon-fibre composites, are then combined and cured with layers of carbon-fibre. A graphene nanoplatelet is a small flat shape – very small, microscopically small, in fact. When you put those platelets into a resin system and mix it with your normal carbon-fibre layers, you greatly increase the inter-laminar bond strength, amongst other mechanical properties. Previously, when you relied on regular resins to hold the carbon-fibre layers together, there’s the possibility that those plies could shear apart – a common and well-known Achilles’ heel of composites. By introducing other structures within the resin, you can increase the shear toughness.”
How much of a step forward is graphene technology?
“We think the properties of graphene are pretty mind-blowing. Some of the mechanical properties of graphene-enhanced composites can be improved by double-digit percentages compared to regular carbon-fibre composites. In engineering, we often talk about improvements in terms of fractions of a per cent; to suddenly introduce improvements of this order is incredible, but it gives you a very clear perspective on just how much we’re discovering about the properties of graphene, and just how much it’s re-defining our existing understanding of materials science."
