Although all of this is interesting to read, this is all speculation. To my knowledge, MB only gave a tiny insight on how this material used for the Ultra line came about. But again it's interesting reading your post.
It's all speculation Leif and as you say so often "lol" about everyone who does such
Why? Why couldn't it be a demerit?
Johnson noise is proportional to square root of resistance. Since superconductors have higher resistance at room temperature, they actually have higher noise than copper/silver. It is when the alloy is at superconducting state that it loses its resistivity, not at room temp. If what you assume is true then electronic instruments would use them but they do not.
Again, CERN uses them at near absolute zero. Their material completely acts differently then. It is a sudden transformation that occurs that does not exist otherwise and certainly not at room temp. See this graph:
What you demonstrating is that as soon as people hear the word "superconductor" they assume goodness. Simple look under the cover shows that it has no benefit and actual demerit in real life. The knowledge is specialized so companies are safe in assuming people won't look under the cover.
Why would anyone buy or even try a product that makes unsupported technical claims?Speculation is just that. You should pony up and buy yourself an Ultra cable and then tell us what you really think.........
Any word on the phono cable offering? Will they have a phono for the lower tier? Those ultra's are pricey. I'm sure they are substantial, but unfortunately way beyond my budget.
Because most products that make just supported technical claims concerning sound quality are uninteresting ...
but I suppose we all acquire products to fulfill our own particular needs. technical validation is just not a need I have.
Biases for needing validation through measurements are just as bad as anything else in the grand scheme. It's not as if you do yourself a favor by going with something that appeals to that immature sensibility, but you actually don't like to listen to as much.
But I still think cable manufacturers should publish basic RLC figures. Not for determine how good the cable sound. But a way to determine whether the cable is suitable for certain loudspeakers. Some loudspeakers do not like high capacitance or inductance.
MB is not alone in not publishing any data. Most high end cable manufacturers never publish any electrical properties of their cables.
I would also say that I'm sure there is technology in the aerospace industry that would be beneficial in building a audio cable....
