Hi, I was just wondering how many people use RCA single ended vs. XLR cables to their amps that sit next to their speakers (longer runs).
I'm not. I do not see significance in a popularity contest.I'll be honest I'm mostly interested in numbers.
XLRs enable balanced operation. Balanced operation cancels inter-component ground noise. Ground noise voltage between components causes ground noise current to flow across an unbalanced interconnect's ground conductor. Ground noise current through the resistance of the interconnect's ground conductor develops an undesired noise voltage that gets amplified by the system the same as would a desired signal. The greater the resistance of the interconnect's ground conductor the louder is any ground noise. Unbalanced interconnect ground conductor resistance is proportional to the interconnect's length, which makes a long unbalanced interconnect's noise more audible. I should note that ground noise current (aka; common-mode noise) can also flow across a balanced signal interface, it's just that a balanced interface cancels the noise common to both conductors by design.
Components having balanced outputs amplitude twice that of their single ended outputs probably utilize differential signal stage topology. Differential signal stages offer several benefits, such as reduction of even order distortion, reduced signal induced modulation of the power supply and increased effective slew rate. Differential circuitry is not, however, synonymous with an balanced signal interface. In fact, a single ended signal stage can utilize a balanced signal interface just as effectively as can a differential stage.
My main interest is knowing the "why's" of each of us ...
Is the purpose of the poll for XLR and the sonic boost? or is it for the security of the terminations.
IOW Lamm uses XLR inputs to amps and outputs from the preamp however they are pseudo balanced
