Curious what you guys use for cables with your Lamms?
I used Kubala-Sosna Emotions throughout for a long time. I switched to Master Built Signatures 5 or 6 years ago.
Hi Oxy
About to embark on same adventure
Had m2.2
Exchanged for m1.2 for greater purity
Found not quite loud enough
About to get an additional m2.2 pair for the bass
Should be interesting
I must admit having had both
U don't give up much with m2.2 and gain in power!
I have used the Russian equivalent valves with great success and a bit cheaper than USA nos tubes
Happy listening
Awsome, thanks for input.... my TAD REF need power to come alive ,and 2 pairs of m2.2s finally are doing the trick, and in spades. could one pair of m2.2 suffice? most certainly, but too much of a good thing is never enough...
a noticeable upgrade was adding the SRA platforms. count me a believer.
btw, love the morels- great speakers- enjoy!
Awsome, ihave using siltech cables forever and a half... silly expensive but really render great timber and are quiet.
on the 4 LAMMS i use the ruby double crown cords.
steve, beautiful room!I just finished auditioning Master Built Ultra PC's on my Lamm ML3's and IMO and for my ears they were better than any other PC I have ever used in my sound system. If you're paying $$$ for Siltech you just might want to give these a listen as they too are very expensive. They won't disappoint. I intend on buying a pair of these for my amps.
As for stands I'm sure your SRA is superb as they were on my short list for amp stands and racks. When all was said and done however I not only did my amp stands but so also my entire front end on Critical Mass Systems and there has been no looking back
You can read about it starting here....
http://www.whatsbestforum.com/showt...Steve-Williams&p=420765&viewfull=1#post420765
heard about master built cables but have not made the move to try them out... i shall in due time.
the 3 prominent stand builders- CM, HRS AND SRA all have their strengths- and all 3 work well.
