Thanks Detlof
You have a very extensive and sophisticated system so fitting the Everests may well be a more complex exercise which needs a bit more time.
The right thing to do as you say is to persevere, let them settle in and listen with the full suite of Everests, If they don't suit the system so be it but again as you acknowledge they may be exposing some hitherto hidden small weakness in the system. That would be something of a mixed blessing because I imagine identifying the source of it may not be straightforward.
Good luck!
Thank you Barry. Well, the Purist disk took care of that "hidden small weakness", which by the way was not small by a long shot. All is back to normal. The question is where did the degaussing take effect. Since the system sounded right before the Es were added and with the Es installed sounded wrong in the top end and the Purist did bring the sound back to normal with the Es installed, the assumption seems permissible that not the system per se, but the Everests were changed for better sound by the degaussing process and by prolonged use. Simply put, they need to break in, so my hypothesis. So far in my thinking, my rig was and is ok and now, with the obviously tamed Everests I am hoping that they will still bring those improvements you and others are writing about.
