A single ended amplifier will not drop into Class B at all. It cannot as it must trace the whole waveform, unlike a push/pull amp where one tube turns off in Class B. The NAT SE2SE seems to be go into Class A2, where the grid is driven positive (normally not an option for most SETs). When this is done much more power can be generated but with a significant increase in disotortion (but it is not clipping).
Whether or not the Transmitter or Magma can do more depends on the design and whether it leaves Class A1 and go into Class A2 or not.
I seem to remember that the SE 1 MKI never left A1 and made 15 watts...pretty normal for a 211 SET. Also, the bigger SE3 made far less power than the SE2SE was able to do.
It just so happens there's one going for a very keen price on audio-markt (well, keen by European standards). I've been quite tempted myself.
Micro, what is the practical relevance of the NATs SE2SEs triodes being parallel single ended 211s, rather than push-pull?
Does this make them more suitable to Apogees duties?
We know that the main distortion spectra of a push-pull topology is quite different of that of a single ended amplifier, but I have little experience with SE's and Apogees, I can not be of help concerning your second question.
I have seen big powerful 500W SS amplifiers that could not drive properly some speakers and the same speakers driven with success to loud levels by 70W tubes, IMHO in this hobby we have more exceptions than rules.
One of the big mistakes audiophiles make (including many on this forum) is that high power = dynamics and therefore "live" sound. They think that compressed dynamics, which give a flat and boring sound, is solved by more power having been taught that compression occurs when one reaches the clipping point of the amp.
What seems to not be generally realized is that amps can sound compressed right from the first mW and it has to do with circuit topology and not power. I had an amp in the past that would sound "constipated" and the sound would not express regardless of the level. You always felt the urge to turn it up more sound the sound could get out...but it never did. This was an extreme case of an affliction from which most amps suffer.
The reason most amps don't sound live has nothing to do with power output and everything to do with circuit and power supply design.
On the right speakers (there are limits related to clipping with low power) a 2 watt SET will sound more alive and dynamically expressive (particularly for microdynamics) than pretty much any big SS or tube amp.
Not my experience. Within the constraints of speaker power compression ( In itself a serious and poorly understood issue) and of amplifier quality , I would just say it ain't so. Perhaps we should open a thread on this.
I think DDK has often said he has not found a high powered SS amp he likes...i hope i'm not taking that out of context.
I agree it would be good to read a new thread about amp design. Perhaps in the spirit of a here's WHY something happens as a result of the circuit design, power supply build, etc...and also the practical implications on the speaker of differing types and the speaker interface which i have read repeatedly (and reliably, i believe) is absolutely crucial to get right.
. . . my sweet zone for amplifiers, tube or ss is from around 20 watts to 50 watts. As I mentioned earlier reason I gave up on Apogees was because no amplifier in that power range I know of can drive them to satisfactory levels.
david
Yes, we should have a thread on it, including also the speaker efficiency - an even less understood subject!
What would be a satisfactory level, in decibels, for you, Dave?
20 to 50 watts just ain't enough for them Apogees!
I am struggling to understand why your perfectionism about amplifiers caused you to give up on your favorite speaker.
