Hello Micro
No not really I am very skeptical. Here is the rub, parts do change over time and temperature but usually not enough to take a part out of it's tolerance range. My gripe is even with accelerated aging, which part screening does do, the parts are typically still in tolerance. So if you have a 5% resistor it will still be a 5% resistor after screening but it will have a shift in value. If the design can tolerate a 5% part then this shift in value should not be audible. Basically you can have a potential 10% value change from resistor to resistor right out of the box. This is much more than you would get after a couple of hundred hours of operation. You have to remember that in any application parts are not used close to their max ratings for reliability. In part screening you are intentionally hammering them to weed out potential failures. So in real world applications you should see even less change than screening.
You have hundreds of parts all shifting slightly in value that all interact with each other. Why does it always go well? Especially when part tolerance swamps any part value shifts due to "burn-in".
Rob![]()
I'm not sure the phenomenon of burn-in has anything to do with changes in gross values of passive parts, but rather in the interaction of conductor and dielectric. The bulk of it happens over just a few hours, but most things get subtly better for a few hundred hours or more. Those who have built their own components have experienced this... most people have just experienced the more subtle longer term burn-in effects. I think it was Bob describing his 300b amp earlier, that's a good description of what it's like. No hyperbole, night and day...
