Peter, my only examples are in Hong Kong and I'm no longer in business. As for sharing more information, you may recall I've done so in time past at the expense of much energy. But the RTS is built on the premise that isolation of any type (for sensitive instruments) is just a crude and grossly inferior execution of the one true vibration controlling methodology, resonant energy transfer. Which works every time and is quite predictable for every sensitive instrument and speaker. At least when the methodology is taken to the extremes.
Yes, theoretically if all components and speakers were built relatively the same way with similar structural integrity, materials, and weight then yes, my products' effects or benefits would be roughly equivalent for all components and speakers.
For example, assume for the sake of argument that mechanical energy (including perhaps all energy) loves to travel but when its travel is restricted will release within. If a speaker cabinet's structural integrity was based mainly on MDF (medium density fiberboard), this is a horrible conductor for mechanical energy and sonic benefits remain quite minor but should still easily outperform others' more compromising solutions. But if that same speaker was constructed of say T-6061 aluminum, the benefits would be multiple times that of the MDF cabinet version. Simply because aluminum makes for a far superior conduit for mechanical energy.
In other words, if the vast majority of mechanical energy (i.e. air-borne and internally-generated vibrations) normally trapped within a component or speaker is never able to reach my products then my products are unable to perform at their intended potential. Components attract unwanted mechanical energy much like a lightning rod attracts unwanted electrical energy. If the energy captured at the lightning rod is not tightly coupled to a grounding wire, that energy cannot transfer out and that's where catastrophic results occur. Likewise, an inferior grounding wire, or a single compromised connection is enough to severely restrict the unwanted energy's ability to travel and will induce results similar to no grounding wire at all.
Again, for sake of argument when energy cannot travel, the object containing the unwanted energy must absorb the full brunt of that energy as it releases within and in particular at the most easily excited objects within. But if that lightning rod is tightly coupled to a grounding wire and grounding spike, then that unwanted energy is expediently transferred out of harm's way before it can induce its catastrophic harm. The same is true for your components and speakers and the unwanted mechanical energy they attract. Hence, I consider my product to be the most extreme grounding wire I was able to conceive at that time.
This goes against the grain of many (99.999%?) but at least some realize that electricity is just another variation of mechanical or vibrational energy and hence the concepts and principles and solutions remain much the same too.
I understand it's all highly controversial because everybody and their mother is convinced isolation is a valid methodology and solution. Yet in reality we give the distortions induced by mechanical vibrations so little credit that nobody balks or cringes when they see a picture of a speaker with its 12-inch side-firing woofers facing directly at the tube amps just 2 feet away. Nor does anybody balk when they see a picture of a center speaker placed on a rack with components (sensitive instruments). Yet, everybody is up in arms thinking of all the potential (and fictitious) harm of vibrations coming up out of the flooring system trying to infect their components and even speakers.
I postulate that nobody balks because if one were to set a center channel speaker directly on top of a component or aim a subwoofer firing directly at a component, those who've done so did not hear any degradation in sound whatsoever. For one very simple reason. Because our sensitive instruments are already so saturated with so much unwanted and trapped energy, they cannot sound any worse. In fact, I consider unwanted mechanical energy to be the single performance-limiting governor that makes every last reasonable quality-oriented playback system sound more alike than different and none of which can even remotely approach the absolute sound. But that's me.
