Jazz at the Pawnshop was recorded on a IV-S...I have some recordings made using small Nagras such as the 4S...
http://www.revox.com/en/news/news-details/article/revox-und-horch-house-vereinbaren-enge-kooperation.html
I hope this actually gets built and sold.
My interest and hope is that more AAA reels ensue![]()
I agree completelly, your words must be written on stone !!! Even if "technically" we are Orch House competitor in this small market when this deck come out this can give a real boost to reel to reel world !... If the sonics are equal to a typical prosumer model with good-great aftermarket prepro (BH, King-Cello, Doshi, etc) this could be a big deal ... If the sonics can compete with the big boys (Ampex ATR-100 series, Studer 820, etc) then that could be a game changer. Larry
I love Lyrec Frida and when a week ago I see the "look and feel" of the new Revox I think immediatly to Frida alluminium beam and print motor ! I own one of them and I am rebuild it from the ground upDoes it still has aluminum die cast frame? Lyrec PTR-1 did away with light I beam aluminum sheet. The same practice for Tandberg decks. They rely on thick head block and guide rollers. "Frida"'s print motor also contributed to its slim form factor. It certainly help in portability.
Thought this might be of interest here - http://www.analogplanet.com/content/new-revox-details-emerge#P8MssYbuFHiLZzv0.97
"Butterfly heads" are a no go for me.......
Yes, it does not seem to be a good approach either for those wanting mainly to play pre-recorded tapes ...
Micro - what is issue with butterfly heads? I know nothing of r2r machines so curious.
Thanks very much for providing this explanation.The butterfly heads have wider cores than the standard heads. If you play tapes recorded with standard heads in a butterfly head you get a lower signal to noise ratio, as you will be adding noise from the erased part of the tape. See http://richardhess.com/notes/2007/0...2-track-tapes-on-a-din-stereo-butterfly-head/
The butterfly heads have wider cores than the standard heads. If you play tapes recorded with standard heads in a butterfly head you get a lower signal to noise ratio, as you will be adding noise from the erased part of the tape. See http://richardhess.com/notes/2007/09/12/playback-of-nab-2-track-tapes-on-a-din-stereo-butterfly-head/
