I have overwritten permissions temporarily to allow you to see images from ASR Forum. See above: http://www.whatsbestforum.com/showt...g-Measurements&p=393763&viewfull=1#post393763And as I can not see your images at WBF, I will not comment on them.
So you stated an irrelevant fact with respect to Entreq?As usual in debates, the conclusion was yours, not mine, you would have the responsibility of killing the guy.
Again, that is not what the papers are about. Let me quote you the first line the Intersil App note you posted:And sorry, IMHO the papers help interested people understanding the real problems in assessing the operation (or no operation, surely) of the device, as they show RFI problems that can exist in real devices.
"The proliferation of wireless transceivers in portable
applications has created a need for increased attention to
an electronic circuits' ability to operate in the vicinity of
high frequency radio transmitters. "
The bolded parts should make it clear that this was an irrelevant paper to post. But I will expand to make sure.
Intersil makes Bluetooth silicon and one of the primary applications of Bluetooth is for transmitting audio. They are trying to raise awareness for designers that when you put a 2.4 Gigahertz Bluetooth transmitter right next to an audio device in a small portable device like a smartphone, Bluetooth speaker, etc., that you have to be careful as one can bleed into the other. They build a test fixture that injects up to 6 Ghz signal into the audio gear (second harmonic of 2.4 Gigahertz is 4.8 Ghz so you need to measure at least up to that point), and identify which circuit components can be susceptible to receiving and demodulating Bluetooth radio.
There is no applicability whatsoever to Entreq in any of this. You don't have a Bluetooth transmitter sitting inside your pre-amplifier and your designer, especially in high-end equipment, has made sure that radio frequencies don't bleed into their circuits. And even if you did have any of these issues, the last thing in the world you want to do is erecting an antenna in the form of a long wire from your equipment to an unterminated load like Entreq.
Your conclusion that audio equipment then has RFI and that it needs to be tested to 6 Ghz based on this paper has no merit at all. It is just a technique of throwing out technical stuff at people, hoping they don't read or understanding them and scoring a point. Please don't do that in this forum. It wastes time and energy to go chase this stuff.
Unfortunately you use your habitual technique - you quote a little part and not the interesting part where it is seen why up to 6 GHz should be measured. As soon as equipment has digital components with digital waveforms these frequencies exist in the device - you do not need a Bluetooth transmitter.
Please note that I do not ask - please do do not go on using this small quotation technique. I (and other forum members) already got used to it.
Does that mean the entreq is not effective in an analog setup?
Not a problem here. We have measured, and the results are positive and characterize the device nicely. Unfortunately that "positive" effect, is a negative thing with respect to what you want to have in your audio equipment. We don't want to inject noise into the equipment, nor transmit more of it into air.Keep in mind the objectionist's creed-"if it can't be measured, it must be bunk."
Of course, this concept ignores the fact that there is much in this world we have not yet learned how to measure.
Most probably, specially if it was all tube equipment, including the power rectifier diodes. Unfortunately most analog equipment has digital micro-controllers for remote and switching, although some purists disable the clocks it after a few seconds inactive. IMHO it is why listening tests should be carried to determine the modus operandi of the Entreq - I accept that I can be completely wrong about it, I never handled or tried it.
Why don't you quote the interesting part then? And what on earth it relates to as far as Entreq?Unfortunately you use your habitual technique - you quote a little part and not the interesting part where it is seen why up to 6 GHz should be measured. As soon as equipment has digital components with digital waveforms these frequencies exist in the device - you do not need a Bluetooth transmitter.
What is the small quotation technique? You put forward an application note with this preface:Please note that I do not ask - please do do not go on using this small quotation technique. I (and other forum members) already got used to it.
I do not have the time or expertise to debate in depth the articles I refer bellow, but I could easily afford the time to read and understand them.
I am not interested in temporary permissions in forums. What I see in WBF is a cheap hand held meter reading in the 40 Hz – 100 K Hz bandwidth - most probably the reading is dominated by the 60 Hz value. Completely meaningless IMHO. Long ago I have built similar devices for secondary school physics students from plans in hobby magazines - they had a lot of fun using it.
It would certainly be very interesting if users with digital systems reported benefits more than those with analog. If so, it would be an avenue worth exploring
I understand. This device though, is unlike many. It has only a single wire going to it. ...
It is built on an assumption that if you take the ground of a system and "bring it" to some device, you can do some good. The problem is that no "bringing" occurs this way. Electrical signals follow very strict rules. If you have two paths for example, they take the one with least resistance. In this case, this device has extremely high resistance (really impedance). So the currents that want to flow, will flow on your signal grounds already in your pre-amp. They don't "want" to go to this device.
I tried the Entreq on both analog and digital gear; it did nothing to improve either of them.
It is a common aspect of most tweaks - their action is very dependent on system and electrical environment.
And of course of state of mind...
Frantz,
I was expecting your comment. Can you tell us how do you manage to turn your state of mind for power supply quality permanently on?![]()
That assumes there is "action." If there is no "action" then it doesn't matter what system you plug them into. People have come up with all kinds of tweaks. It can't be that they are all effective. Some must be failures. Assuming that they all work and it is your system that is letting you down, is again an argument in dire need of some data to demonstrate validity.It is a common aspect of most tweaks - their action is very dependent on system and electrical environment.
