Kef ls50 $1,200.00
pangea - ds300 - heavy duty speaker stand $170.00
svs sb13 $1,500.00
hypex nc400 mono amps $1,500.00
gustard x20u $900.00
aurender n100h $2,200.00
luminous audio silver reference xlr 2m (dac to amps) $900.00
luminous audio synchestra rca 2 m (dac to svs) $500.00
32 feet canare 4s11 speaker cable / bi wire $42.00
furutech ft-211 g amp side $93.00
2 sets furutech fp-201 g speaker side $106.00
kimber - silver b-bus usb cable 1.5m $230.00
5 - pangea audio ac 14se mkii 2m power chords $350.00
salamander a3/b 28" rack $205.00
grand total $9,896.00
You have exceeded my $10k budget when you add a dedicated server, streamer, all the software licenses for Roon and HQ Player plus at least a couple fifths of liquor needed after trying to figure out all the settings and stuff. The biggest thing is I will have personally listened to every piece of equipment on the list all together in my listening room.
Mike you make it sound so easy........My music files are on the 4TB of internal storage of the Aurender N10 and a 12TB USB drive.
We will discuss the streamer setup in another thread when I get ready to take the plunge. You gotta admit my $10k system is not bad, come on I know you have it in you to give someone a compliment.![]()
Just give a little Mike........just a little........Nobody else has included as much detail and thought. I know you can throw a compliment........Try it you might like it.![]()
Same here Mike. I have a tube / fet linestage and tube mosfet mono amps I built from a very good friends design back in the late 80s, sounds as good as anything else I have in my system. I have built numerous speaker systems through the years. The system I came up with would be something anyone could buy and plug it all in and get close to the SOTA. All items are readily available and well known and respected. A little DIY is required with the amps and the speaker cable but nothing like brain surgery.
Marty - You set yourself up for failure by posting it in Mike's corner........you know he ain't cutting you any slack.![]()
I rather receive $5,10, 100 thousand dollars worth of knowledge while the person calls me !@#$%^&* names, than compliments & misleading knowledge or hiding the significant facts.John you are right........I am giving up and moving on to smoother pastures......
Very refreshing, and yes that is the biggest thing when it comes to recommending something. I would have posted this system in a different forum.
zz.
