Has anyone heard this supposedly incredible $10K system?
interesting first post ....
I had no intention of talking about technology in this thread. You're the one that decided to just say my submission wasn't good. You don't even take it seriously into consideration.
At no point did I say I build anything better. Please, don't try to align yourself with the authenticity of designers you share nothing with. Their validity is not yours. And my opinion for what I like is mine.
NC400's and the SMPS's are available to the public through the right channels. Some people have got the NC1200, but it's not suppose to be readily available.
For the ESS DAC my needs may be different than what the LDO offers, and I prefer to try multiple things instead of deciding what's best on paper alone. That's not the same as claiming I'm a better designer. And I PM'd you on that subject because I was curious, and even in the PM you got all uppity as if I took a dump on your design. For public record, you like to share PM contents in public.
When I say you don't know what you're talking about with SMPS's, that's not saying Bruno doesn't know what he's talking about. There is no synonyminity between you two; to him you're a nobody as much as I am. The reality is Bruno is fully aware of everything I've mentioned about his SMPS's. And there's nothing wrong with him designing one similar to all SMPS's because their basic function requires a few things by their nature; he just makes his much better. His SMPS is his best chosen fit for the Hypex business model. Clearly based on where you see them, especially in speakers, a LPS doesn't have as many selling points for those wanting plug and play solutions in specific enclosures. He also wouldn't be the manufacturer of the LPS in the same manner, so he wouldn't make nearly as much money - not owning a transformer factory etc. He made the right choice for Hypex, and unless he's specifically stated no LPS he tried with his ears was as good, then I'm only inclined to believe the SMPS was chosen because it fits the business model and performance goals, not because "it's just the best ever look at the graphs!!!" There's nothing wrong with that. I do the same thing, choosing what fits as opposed to attempting an end all performance because it has no end. Ceramic circuit board with silver pours, or whatever, isn't always a realistic option.
I was excited about this thread when you said you were going to make it. But I thought more people would submit their ideas. Perhaps some questions would be asked as well. So far I'm the only person to submit something and it gets poo poo'd. But even before that I should have been smarter to notice the thread was about you. You basically tell everyone what's what, and deny their participation unless they'll drink the Kool-Aid. This is like so many threads on this forum where you simply try to dominate by posting.
Best of luck with your endeavors Blizzard.
Here are a few observations that I have had (listening.....so its real, not imagined). The Hypex modules, as every other thing on the planet has a sound.....and it is not totally transparent....nothing is. If you use a better fuse in a Hypex amp it will sound better, if you use better connectors it will sound better, if you damp the chassis and modules it will sound better, if you isolate the power supply from the output module it will sound better.....but here is the real kicker......if you change the output filter caps in the NC400 to my modified Wimas you get much, much better sound. This is according to everyone who has tried it....they heard the difference. I don't know what caps they are using on the NC500 but whatever the caps are and whatever the inductor is......affects the sound. I made my own toroidal litz wire output coils when I was making/selling UCD amps and the handmade toroidal coils beat the stock ones......there is no free lunch...everything makes a difference. However, I will say that a tweaked Hypex module with a great discrete circuit on the input would be hard to beat. But it is not perfect.....not now, not ever. If you put WA quantum dots on the power supply caps it will probably improve the sound...same with mounting a Pulse Gen ZX inside the box and also using Magic Tubes inside the box.....I have not tried these things in a Hypex Ncore amp but these things improve every other component I have tried them in and same with my customers.
For this $10K list I would add modding the Gustard and possibly making an LDR kit from Tortuga Audio for volume (may sound better than the digital volume in the Gustard). You can cut in half and hardwire one long interconnect directly to the LDRs so there is only one interconnect.....very trick! Other speakers worth considering: New Hawthorne Audio open baffle speaker with 2 servo 12s on the bottom, the Vapor Audio Stiff Breeze, the limited edition open baffle speaker from GR Research with servo subs. The Hawthorne uses an AMT down to 1500hz? and is 98db sensitive......the Vapor uses a Raal Ribbon, the GR research uses a custom high sensitivity B&G Neo 3 planar tweeter open baffle. BTW I think the graph you showed for the Mundorf kit is just the specs on the tweeter by itself.....not the measurements of the whole speaker....I could be wrong on this, but don't think so. I am sure the Mundorf would be nice.
https://www.hawthorneaudio.us//cata..._id=67&zenid=65c37917fc8ab7b8de902e4e9bbadbed
http://www.audiocircle.com/index.php?topic=138878.0
http://www.vaporsound.com/speakers/stiff-breeze/
http://www.audiocircle.com/index.php?topic=138009.0
The LDO about to be delivered I am sure meets its specs. However, what specs make good sound? Steve at Empirical Audio is really adamant about using his custom Hynes regulators because he thinks its the combo of low noise and super speed these regulators have that makes for the "analog like sound" he achieves with his DAC. Are these new LDOs fast? How fast? We will see whether this new regulator is the cat's meow or just another chip. I will A/B it with my discrete shunt regulators (super fast) and see which makes the best sound. I don't care if it is the best or not. But I surely would not believe anything anyone says about this chip (or any chip or anything) unless it has been subjected to rigorous listening tests (the only thing that matters.....the sound!!!).
Alternatives to the MA30s and amps:
http://www.pureaudioproject.com/product/trio10-mundorf-amt-open-baffle-speakers/
For cables, I'd recommend Audience Ohnos:
http://audience-av.com/cables/ohno.html
*My posting a system here were intended for fun light hearted participation in the day-dream $10k system. I did not view this as a commercial endeavour so I was completely honest, including offerings that are not publicly searchable.
They were developed to be the ultimate LDO for the sabre DAC's as well as simplify the design of the DAC. This will allow much higher performance out of much cheaper DAC's from the past.
These regulators are used to power the digital end of things. They are not for the output stage. The data sheet hasn't been made public yet.[/QUOTE
These regulators are for the 3.3v supply. This is the analog part of the chip and includes the output stages inside the chip.....so you are wrong. In fact, there is one volt RMS analog signal coming out of the DAC....along with current.....you can use it either way (voltage out or current out). It is the most sensitive power supply for the chip. Here is where we will do our A/Bs with this regulator versus others.
It's designed to power the chip which is a digital to analog chip. Digital goes in 1 end, analog out the other. I know what it's for.
I think anyone can figure this out by looking at the simple block diagram. Reading the product brief is helpful as well. Anyways this is the wrong thread for this discussion.
Cool speaker design. Have you heard them? 10" is quite large for midrange reproduction. It would be interesting to see the off axis frequency response plots. Grant Fidelity who sells the MA-30 sells the bigger brother to it as well:
http://shop.grantfidelity.com/PureAudioProject-Trio15TB-Open-Baffle-Speakers-pair.html
I haven't heard them but my friend has, here a review:
http://www.stereotimes.com/post/pure-audio-project-trio10-mundorfamt-loudspeakers/
So you are recommending a complete system, you haven't even heard ?
Interesting.
