Ray I can probably say you are much more savvy at using these software programs than I am.
That may be, doesn't mean you can't learn.
“If you want to get laid, go to college. If you want an education, go to the library.” ? Frank Zappa
I cannot speak for Ron since this is his post but I am looking for something simple to operate and get repeatable results.
I cannot speak for Ron since this is his post but I am looking for something simple to operate and get repeatable results. Some of these programs would require me to get an EE degree.
Correct. Used to require membership in HTShack forum but no longer.I checked out REW, very nice feature set for being free. Am I correct this is free and the author just asks for donations?
fuzzmeasure. It's beautiful and user friendly. You prolly won't need to ask anyone for help or read a long help file. It's that easy. You need a mic and ADC/mic pre. I wouldn't use a USB mic. You can get a decent calibrated mic from cross spectrum, as previously mentioned. TEAC makes some inexpensive ADCs which are very accurate.
If you are in fact closer ( to me ) than Beverly Hills I can even pop over and measure the room for you?
Keith.
Ron Hi, that is gracious of you, well if you need any help, it really is worth acoustically measuring your room, the results are always fascinating and revealing.That is a very kind suggestion, Keith. Unfortunately, the listening room will not be put back together for several more months. And it is in Beverly Hills. (You are welcome to visit!)
