Hi Mike,
Great to hear that the Elrog 300B's are working out so well for you on your Lampi GG. They would be my first choice too. Have you ever had the opportunity to compare the Wireworld Platinum Starlight 7 USB Cable to the Totaldac USB Cable? I'm currently getting terrific results with the Wireworld Platinum Starlight 7 USB Cable on my Esoteric K-01X DAC. Amazing transparency with tremendous detail and nuance.
Best,
Ken
mailbox cleared now.
I dont know.Norman - can you interface foobar with Bughead?
the Elrog 300b-Takatsuki 274b combo on the GG is fantastic!!
stone cold and brand new the Tak 274b recti takes things a significant bit further after a brief listen. lower noise floor, more detail, more holographic, and even sexier. it builds on the Elrog's strengths, and then adds a bit of dynamic energy and authority.
He is using the Total Dac. I use the Corning with Regen green.
I got home late tonight/early this morning from my brief business trip to Miami......stopped at my work on my way home from the airport to pick up the Tak 274b that arrived Monday. and just now plugged it in.
more real.
got to get to bed now but i'll be having sweet dreams......
Morning Norman, it's worth noting that Bill's comments on my Sablon usb cable were actually relative to his own TotalDac one. There's a full comparison in his latest review which is now live on Positive Feedback. Cheers Mark
Gosh Mike, i HOPE yr Elrogs last.
When I was running Audion Black Shadow SETs last yr, I went thru THREE pairs of Elrog 845s in 9 months.
They were stunning re SQ, absolutely SHOCKING re unreliability. Unacceptable.
So Wisnon, Mike SHOULD be ok w/the Elrogs? I do hope so, they are genuinely stunning tubes.
Mike is more than 'ok'.
I realize you were speaking to reliability. and I was speaking about my listening. but the Elrog's seem perfectly behaved so far after a week and 50-60 hours.
and the exceptional build quality of the Takatsuki 274b as a recti likely only helps keep things stable.
do I have to go to work today?
I learned these tricks from Ralph Karsten of Atmasphere. When I get new tubes, I burn-in them without applying HV for about 100 hours - I just take out the B+ fuse of the old MV125 amplifier I use for this purpose.
In normal use the tube should be warmed for two minutes before applying HV - a time delay relay is great for this purpose. Using these two methods, the early failure rate reduced to almost zero in hundreds of tubes.
How is this done? By HV you mean high voltage?
