Very few things ever are in high end.Even that doesn't seem to be clear cut. Some prefer Duettas over Divas. Interesting world, non?
david
I had the Grands when they came out. They're very difficult to drive and and 6 channels of powerful high end amplification cost a ton of money. Setup was complex and the active Krell sub that came with it was a POS. The Divas are a better speaker IMO.
david
Hi David,
Which of the Apogees was your favorite and why? Was it the Diva? There has been much talk about the Full Range (as evidenced by the name of this thread), so curious given your extensive experience (including ownership of the legendary Apogee Grands.)
So, yr recommendation is Apogee Graz Full Range w/SS or hybrid amps (since these are planars def not amenable to be driven by tubes)?
I relation to Trios w/Basshorns?
Hi Lloyd,
For me the two best Apogees were the Diva and the FR, still prefer the Diva over the FR for overall balance. Apogee hit the sweet spot between sound quality and power needs with these models that imo missed with some of their other designs. The FR & Diva are very close sonically, though I would say that the FR is a bit more transparent but also a more difficult load, so in the real world the Diva would end up sounding better balanced. The smaller Duetta & Scintilla weren't properly balanced and with Scintilla having somewhat of a disjointed bass from the rest of the speaker. I think that it was because of the very difficult load it presented to the amplifier more than the speaker itself.
I would categorically call the Grands by far the worst speakers I ever owned and am EMBARASSED![]()
!!! to say that I went whole hog on that system. $100k+ for 6 channels of Krell Audio Standards, the most disgusting sounding amplifiers I ever owned, add to that the horrible sounding KRC-HR pre, $80k-$90k of MIT wiring, the sources and you're in the half million dollar territory for a sound that at best was nauseating! The Grand was truly the Frankenstein (Apogee!) MONSTER. Starting with the disgusting DAX crossover that they had cooked up, complicated software on top of undependable hardware, easy to crash and impossiblet to tweak correctly. This xover already destroyed the sound by itself but the ridiculousness of the Grand's design didn't stop there. The $hitty Krell active subs were a sad joke sonically and served as shakers under the tall ribbon panels. They also raised the main panels above the listening position, your ears are lined up with the subs instead of the panels in this speaker. I just can't believe that the same person who designed the other Apogees had a hand in the Grand Caca! Whoever said "ignorance is bliss" hadn't heard this system!
david
Wow! That is certainly clear enough! Thank you...I will be sure to try to hear the Divas or Full Range.
Hi Lloyd,
david
I hope I scared you off the Grand Caca for good Lloyd. The original Diva & FR where great speakers as are your Wilsons, good thing about your amps is that you can try them all.
david
I know, it can get strange....I like the full honesty. The previous sentence is honest with NO double meaning. You have to be careful around here.
zz.
david
But what if a member owns or sells Apogee or Krell? They may be offended. Is this Okay?
And heaven forbid if someone from Apogee/Krell was to to read that post. Their feelings may get hurt.
Thank you; you are astute to point that out.
I personally feel that people should spend their time being offended by the 100 to 200 elitists that control the world & are raping us. OOPS, that might be considered politics [???]. Please do NOT show this post to anyone.
zz.
Yes I agree. If hearing an honest impression of an audio system is going to require years of therapy to get over, perhaps audio isn't for you. I'd suggest total isolation in a remote cabin, far far away from other human beings.
I realize the post is not directed at me seeing as I do not need years of therapy, BUT how did you know about my remote cabin?I like being a 98% hermit.
