Bill are you playing BHE native feed or upsampling first to DSD256?
If not the latter, try it with the tips and settings I sent to you…In Core Mode, if possible.
Yes….correct and if you do all that in core mode its ultimate magic.
On another note, just in case you or other people know MusikMike of Stereomojo fame and AudioAsylum, I JUST heard he passed away from illness last June (29). Top class person who I will miss tremendously.
Audiophile optimiser
Okay. Not using optimizer - I need this PC for other stuff and even the basic version slowed my machine down horrendously!
you need Windows 2012 RS Standard running in core mode then + Audiophile Optimizer.
Aha. Thanks, Mike. I have not yet sorted a pimped out server - I really need to do that for 2016. My PC is Windows 10 and has to do other stuff so not merely dedicated to audio although it does that 90% of the time.
thanks. I am having fun. these Elrogs seem to really get to the heart of the music. the nuance is addictive.
as Norman mentions, I'm using the Totaldac USB on both my GG and Trinity. maybe at some point i'll play around with others.
With Windows Server 2012, can you still run headless (i.e. can you remote desktop into it)?
How hard is it to setup? I'm thinking of trying it (and purchasing Audio Optimizer) but would like an idea of what I'm getting myself into
Thanks in advance...
Yes, you can run headless and remote it. It isn't the easier OS to work with but if you are pretty good with PCs you should be fine "with a little help from your friends."
Win10 AO is in Beta now and should be ready soon.
Do you suggest waiting for that? Is it expected to be as good?
Go back down to version 5.24 or thereabouts…pre- blockade.
PM me your email addy as well.
