Shun Mook in Canada
bonzo75
25,577
16,883
4,490
London
There are a lot of used Shun Mook resonators in Canada today
If anyone is going to buy, suggest you check, as these are around 20 years old. Weights and diamonds have changed. Also (and please, no anti-foo brigade) there is a dot on each which makes a big difference, and I am not sure if these have them.
I don't have experience with these older models. Just thought I would put that out before anyone who takes my recommendations seriously (if at all) jumps to buy these, as I have been recommending them, and don't want anyone buying and being disappointed if these models were different to the ones I recommended.
Hi B, Bill Ying told me there are lots of fakes out there-- Caveat Emptor--I have the Resonators and Record Clamp-- agree great products if much maligned by the "measurements rule my life brigade"
maybe they should take the blinkers off and listen to music for a change
BruceD
You believe they make a difference then Bruce?
Keith
If they make your system sound different, then they've made a difference. And they do. And so they do.
Keith
No doubt about it but of course only to people that are really willing to listen to what is actually happening.
I have SM's from when they first started selling them(1990's). They all have the dot. In addition, ebony from back then is the real deal. I'll bet today's "ebony" isn't really ebony..
Hi possible. There are some older ones without the dot. That's all I am saying. When people buy older ones they should check
