those look like they were designed by Lambo- which isn't a complement. they actually cost more than one too
Yes the picture was taken in one of the testing rooms of Avalon Acoustics in Boulder, CO. Neil, Dmitri and the rest of the staff where kind enough to let us experience the sound of the beasts named Tesseract. Several people involved in the global audio industry (Italy, Hong Kong, Taiwan etc) where present to assess the quality of the reproduction. Consensus among the listeners on the Extreme transparency, all flabbergasted when they played a 1961 studio recording from a master tape of Beethoven’s 9th symphony. One of the people in the room made the comment that it was an experience of live music versus (dead) reproduced music. When playing Tosca, featuring Guiseppe Di Stefano, the audience discovered new depth in a voice they thought they knew. The presentation of Rossini’s Barber of Saville was amazing and left several people speechless before moving on to Pink Floyd’s the wall and other equivalents of the rock scene such as Deep Purple.
We also got some explanation on the background of the design of the Tesseract. Comments comparing the “Tess”, as the speaker is endearingly called in the house of Avalon, with the air intakes of the Lamborghini Aventador where made on location as well. In the case of the Tess the openings at the bottom are the exhausts of the folded and tapered Transmission line that directs the compressed energy of the woofers outward to the listener. The V-shape is not there to refer to Lamborghini but to refer to many other Avalon designs that have this shape at the bottom of the speaker.
Time alignment and exact constructed volume determine the dimension of each of the components. Where the facetted appearance is Avalon’s brand’s trademarks it is caused by material characteristics, structural integrity of the speakers housing and to minimize reflecting of sounds waves at specific frequencies.
The humanoid appearance of Tess is partly in line with predecessors like the Sentinel, which by the way we were told will be available with upgraded components. The shape, size and location are all constructed out of need for time alignment, volume and minimal reflection. Unfortunately the first customers had chosen for a dark finish that for many of us that see Tess for the first time gives an intimidating and gloomy appearance. Tess was designed as a two tone speaker where the front facets could be any color or even a painted artwork. This will make the volume look more elegant and emphasize the appearance of one of the ladies at the court of Lorenzo de Medici, or to throw in a more contemporary example the singing nun.
For anyone who is serious about audio reproduction and willing to travel to Boulder, Neil and his staff would be happy to showcase this experience to those who contacts them.
Just getting fed up w/plain awful combinations of statement spkrs/megaWatt SS .
@Avalon: so why the choice for powered woofers? Don't you think potential buyers would want to use their own amps to bi- or tri-amp, and use high quality analog amps, and not necessarily digital? It seems like you want tube lovers to not have to worry about the bass, but it also feels limiting as a decision - and why not make it optional, in the end.
All elements in Tesseract are task specific and integral to the design. The powered low frequency section is fully analog with active manipulation of phase, damping, and frequency domain characteristics; no DSP is involved. The amplifiers are a fully push-pull class A/B output stage with switching mode power supply, so they are not digital. Switching artifacts from the power supply are non-existent as the amplifier “sees” only the limited bandwidth of the sub section, not the entire bandwidth of the signal. Modulation distortion is unmeasurable in this application which was specifically tailored for the closed loop load of each pair of woofers being driven. Feedback and EMF characteristics are idiotypic to the drivers under the load presented by the isobaric chamber/transmission line. An external amplifier which was not designed for the demands of these loads would likely be destroyed. Regardless, current delivery and control of 4 large voice coils could not be optimized without fixing the amplifier variable in the equation. By designating amplifier characteristics for the task at hand, we were free to create custom magnetic structured woofers specifically for this application. Each part of the low frequency section would, in a practical sense, be useless unless combined with the other elements within the chain.
This approach allows the user to purchase an amplifier that perfectly fits the sonic "cast" that the user wants to impart on the system...so I would assert that it is actually not limiting at all, it offers much greater flexibility in amplifier choice.
...why not use a linear power supply? And what about acoustic feedback to the amplifier? Wouldn't it be best to house it externally - ditto for the crossover? Or are they already externally mounted, or otherwise isolated
