I would not read too much into the precision of my incremental value ratings between big 7 and GG. Would I recommend upgrading for the additional investment? Absolutely for certain!
Don' t you think that the same amount - say 5 k euro/ pounds- spent for dedicated music server could bring better results?I would not read too much into the precision of my incremental value ratings between big 7 and GG. Would I recommend upgrading for the additional investment? Absolutely for certain!
If I understand correctly from your review you use a standard pc/ notebook as a transport?
This is what I would like to avoid - pc is never ending story, you always have to " audition" improvements instead of listening to the music. My choice is rather dedicated music server like Aurender/Amare Diamond/ Lampi computer. Within a few weeks the Sound Galleries server will be ready.But a modded PC can be easily upgraded. Download software, change ram/cpu
Jriver is not as good an upsampler.
Now I am not saying you will prefer upsampling even with HQP, but it will sound better for sure. Native DSD will sound better. Thing is unless you get a GG with PCM you will never know if you prefer the native PCM as compared to upsampled PCM![]()
I am in favour of playing files as they are registered, in native way.
I am a big fan of native dsd played with my big 7 but for pcm I use La Fontaine which I consider better than big 7 pcm playback.
I think every single manipulation of files influence the quality, I am not in favour of pcm converted to dsd.
For me the top notch pcm are HRx recordings of classcial music by Reference Recordings and native dsd from Fone, CC or Caro Mitis.
Dynamics and resolution are better in pcm and timbre and palpability of music with dsd, as always IMHO.
Thanks Marslo. My - admittedly limited - experience so far indeed suggest that I also prefer all files to be played in their native mode. I clearly prefer my Reference Recordings on my Trinity combo. Need to find out however how good the new pcm application for the GG will be. Lukasz is very, very enthusiastic about his new pcm application.
We are audiophiles. Those who have an itch to upgrade their modded PC, will have the itch to sell their Aurender to get the next server. Just like people do with amps, preamps, dacs, etc. Those who don't have that itch will not change. But modded PC gives more flexibility at cheaper upgrade options than a server in either case. I listen to my music in concert halls, my gear is to satisfy my OCD hobby. One doesn't upgrade from an Oppo to a Vivaldi price for music. He does it because he is a gear head. And that's why he visits this forum. The amount of music discussed on this forum is very low.
I think your upgraded server will have Bughead Emperor (rave reviews, but not an upsampler) and Foobar (upsampling too) too choose from as well. You can also buy HQ Player, which is the best upsampling software out there.
Edit: I just heard that the latest solution is to use JRiver upsampler to 256 which hands off to BE as the playback engine and it sounds spectacular! All this in AO core mode with functionality retained (tablet/Komputer wifi hotspot, etc).
In Linux mode, playback engine is with Dafile, but no upsampling option and Linux is limited to DSD128.
Finally, it all comes with the full 12v battery operation option.
From Facebook:We are flying higher than Baumgartner. In rare thin air of digital computer playback. Using Lampizator Komputer machine with Audiophile optimizer, fidelizer, 2012 core mode and the Bughead Emperor soft. This is as far as I dare to push digital playback to the limit. Pedal to the metal. Wooooowww...
Thanks. My GG also has a pcm application but I used it very little because I clearly preferred the dsd mode and I am very spoiled with my Trinity pcm combo. Btw, my GG will be updated as well and according to Lukasz the new pcm application is much better than the current one in my GG. Very interesting to find out if the updated GG will be able to compete with my Trinity combo.
Hi but have you compared both in the same system? Sorry for the obvious question
Also have you factored in that you can upgrade valves?
Hmmmm, Balanced or SE, SE or Balanced, Balanced or SE![]()
Balanced..... Balanced.... Balanced.... Balanc... Bala.... Bal.... Ba.... B.........![]()
