Turntable Level
VPN
353
163
318
Hello,
What is in your opinion the best turntable level? Why?
- Ortofon - High-Precision Spirit Bubble Level
- Clearaudio Precision Bubble Level
- The Cartridge Man Digital Leveling Gauge (expensive)
- VPI Cross Check Turntable Level
- Avid - Level 45
- Other?
Thank you,
VPN
daytona600
722
151
955
scotland
use these 2 myself
basic & cheap Crossballs - best & expensive The Cartridge Man Digital Leveling Gauge
VPN
353
163
318
Dear Daytona600, than you for your input. I also know a person who is quite happy with the Cartridge Man Gauge.
I wonder what is the second best level, not as expensive as the electronic Cartridge Man Gauge.
number95
384
7
250
jfrech
2,152
749
1,160
Austin
Reactions: kozzmo
BobM
169
9
150
64
Long Island, NY
I just use a small 3" bubble level. I sit it on the platter and rotate the platter in a circle very slowly. If the bubble stays in the middle all the way round I am good to go.
c1ferrari
May 15, 2010
2,162
51
1,770
Just ordered this:
Might be too massive for some tt, but we'll see :
:p
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
^^^ Do you have a link?
Mosin
[Industry Expert]
Mar 11, 2012
895
13
930
I had some custom vials made, and build them into the turntables I make. At least, people can remember where they are. :D
Grooves
152
Pacific Northwest
I like the Digi-Pas DWL-80Pro Mini Pocket Size Digital Level Electronic Angle Gauge, on Amazon. It fits into tight spaces better than my ClearAudio bubble level.
Zeotrope
1,762
1,398
230
49
France, Canada
Hello,
- Avid - Level 45
- Other?
Thank you,
VPN
Best I’ve found is the Mitutoyo 3600. It’s accuracy/repeatability is +/- 0.05 degrees, meaning that repeated measurements at the same spot will be within 0.1 degrees.
Most digital levels are at least 2X worse in accuracy. Don’t judge by the number of decimals on the digital display, that has no relationship to accuracy.
It also means that, with the Mitutoyo, there’s no point in trying to level < 0.1 degrees.
It’s very easy to chase your tail and go crazy trying to get level perfect - you never will - so don’t obsess over it!
Zeotrope
1,762
1,398
230
49
France, Canada
This model has odd accuracy specs:
  • Accuracy of ± 0.05° at around 0° & 90° ; ± 0.2° at 1°~89°
I would say it‘s going to be within 0.4 degrees, not 0.1. “Around 0” is like 1 degree, where accuracy plummets.
That’s fine, just don’t fret over levels < 0.4 degrees. So if tonearm path, front-back, left-right are all <0.4, that’s as close as you can get with this model.
jfrech
2,152
749
1,160
Austin
Reactions: Zeotrope
Zeotrope
1,762
1,398
230
49
France, Canada
In my setup I can’t get my head over the platter perfectly, so there’s parallax error if I use a bubble level.
The main thing to keep in mind (with digital levels) is not to try to correct within the margin of error. If the digital gauge is +/-0.1 deg (most are worse), then that means repeated readings will be off by as much as 0.degree, even if it’s perfectly flat.
So don’t worry if your digital gauge is not reading 0.00 when you’re checking the level. And don’t think that because you have two decimals of resolution it means it’s accurate to a hundredth of a degree (it’s not).
What I did was check the level in 3 places:
1) Along the path of the cartridge
2) Front to back (perpendicular to the front of the TT)
3) Left to right (parallel to the front of the TT)
If the difference in angle of (1) vs (2) and (1) vs (3) is within the margin of error of the leveling tool, you can’t get better.
Or you could just look at the angle at (1) and check that it’s within the margin of error of the tool. That assumes the tool was perfectly calibrated on a flat surface - most probably are not. The Mitutoyo has a way to manually calibrate it.
