Integrated amplifier with DAC or stereo amp and preamp with DAC - advice needed
mirekti
26
Dallas, TX
Hi all, this is my first post on this forum. I find it quite interesting.
Most likely I will end up with Focal Electra 1028 BE, and I am in a search for amplifier.
Could you recommend me something in a price range to $5000 that would pair well with Focal speakers?
I listen to various types of music, but mostly new age Jazz. I would prefer that the combination can be used on 110V/220V.
Up to now my favorite is Parasound Halo Integrated, but not so familiar with other options.
Hegel has an integrated amp. in that price range, and I believe, some even cheaper models.
They were pretty solid every time I auditioned them.
alexandre
A little further up in price ($6500) is the stupendously good Devialet 120... Look for used model (not that many out there on the used market from what I can gleam, though)
Musical Fidelity also has a few integrated options. Something like the Parasound P5 could be up your alley, then you have a few thousand to play with to get a nice, solid amp.
This may sound laughable, but my best system to date has been using the Essence HDACC with a 30 year old Mitsubishi DA-A30. I actually prefer this sound to my SET monoblocks, and I prefer it to any other combination, including the Chord Hugo. That pairing really gives a sense of depth, realism, and spatial quality that I haven't heard since demoing the Wilson Alexias. The Essence offers one pair of RCA inputs and several digital inputs, including HDMI.
Wow, this looks nice (my wife would be happy) and the reviews are quite positive. I was always a bit suspicious about the class D amps, but this one really seem to be good.
Ideally I would test it before the purchase, will see if there are any dealers close to me.
Job 250 monoblocs and Job Pre2 preamp...Total $5100 new with delivery, and voltage selectable. Add$900 more for 3 sweetcords, if you like.
alexandre
I have a friend who bought a Hegel integrated and has had nothing but trouble with it. He has sent it in twice for repairs in the 2 months he has owned it. I'm assuming he got it used, so it may not speak to their overall product quality.
The new Parasound Halo integrated amp @ $2,495 would be an excellent budget choice < $5,000. It has many features more expensive units do not have. The new McIntosh MA5200 @ $4,500 assures top quality performance, reliability, and resale value. A mint pre-owned McIntosh MA6600/6700/7900 < $5,000 would really compliment the quality and appearance of the Focal speakers with no long-term regrets and need to upgrade..
I would look for a good DAC with volume control in the <3.5K range. Best would be a used Berkeley Alpha 2, which typically sells for around that. The much cheaper NAD M51 is also very good choice. Then get Job 225 stereo amp and stay within budget. You could even get the single box (DAC/PReamp/Amp) NAD C 390DD for $2500 and call it a day.
Take a look on NuPrime IDA-16, nice integrated amp with good dac, and price is 2600dollars, new!
Yes, I thought he had moved away from the idea of the incorprated Dac. My bad.
I would recommend Wyred 4 Sound MPre (with built in DAC and headphone amp) for $ 1,099 and ST Mk2 500 wpc class D amps $1,499. Lot's of room in your budget for inexpensive W4S balance cables, etc. The remote control is not the best but does the job. Both does not occupy too much space in your rack and very convenient to use together with 12v trigger. I have them in one of my demo systems driving a Von Schweikert VR35 with pleasing result.
I have a customer who is a long time Bryston user and had gone through a number of more expensive tubed and SS stuff (including Spectral & NAD) and very pleased with this combination as well.
I am W4S dealer but do not hesitate to recommend them to my friends because IMHO they are a good value for the money.
I'm very fond of the Primare I32, for which you can also buy an add-on DAC board. Most of the reviews I've read seem at odds with my experience of the amp -- I found it certainly had that class D "cleanness" but without so much of the edge and I didn't find it bright -- but if it's possible to sample it near you I'd definitely give it a go.
That said, I think the Devialet 120 is better.
