If you are only interested in blending the subs with your system and not full DSP, what are contenders for the best product out there? Or are all products for this purpose commodities, since you do not hear, but only feel those low frequencies?
Well what are you usingIf you are only interested in blending the subs with your system and not full DSP, what are contenders for the best product out there? Or are all products for this purpose commodities, since you do not hear, but only feel those low frequencies?
Well what are you using? I think the miniDSP line has some excellent product out. I myself, I use REW filters and JRiver PEQ - but in my case, the computer is the prepro. I use MathAudio EQ for the mains and I got a decent curve using both.
What do you mean by "product"? Are you talking about software or hardware? Are you talking about a full standing speaker with built in sub? I'm confused since there's so many ways subs are incorporated into full range speakers.If you are only interested in blending the subs with your system and not full DSP, what are contenders for the best product out there? Or are all products for this purpose commodities, since you do not hear, but only feel those low frequencies?
I would think the last thing I would do with MBL 101E MKI or MKIIs is to add a sub. Why would you want this? Do you have a bass node issue? I have owned and tested both versions, the bass is tighter and lower on the MKII but the MKI was very satisfying.
Okay. Is your system source digital or analog? Can you describe it?Hi Dallas,
All I am trying to do is to take the signal from my preamp out and send it to the subs, in addition to sending it to the amplifiers. So I am looking for the subs to augment the bass response that the amplifier/ speaker is already creating.
I strongly feel the best solution always requires a crossover on both the R/L speakers and the sub. You will always get smoother phase at the crossover and hence more even bass. If you have a computer source it's best to use a MCH DAC. But you can still do a crossover of sorts with a 2 CH DAC IF you have a JL Audio sub with E.L.F. function.
Hi Peter,
I think it's all room dependent. I have heard 101's mk1 with subs. In a nutshell, subs are a huge improvement to the already phenomenal MBL time machine. Although the 101 already has an incredible bass response down to low 20's, good subs take it down to very low teens, allowing to hear more of the original acoustical environment. But in addition to lower bass response , the system sounded more musically transparent (not the stupid, annoying resolution of artifacts that people mistake for transparency), they also cleaned up the midrange and highs, improved image specificity in the soundstage, made the 101 even more dynamic, and of course allowed for the bass lines to be followed better, allowing to get into the music even more .
I could go on and on analyzing, but overall realism improvement is incredible. It's like paying $8-10k for $50k of electronics. From what I have heard, other than getting the right amps that can properly power the 101 beasts, I can't imagine a better upgrade.
And for guys who already have the101 mk 1 and love it, and yet are discouraged to going to mk 2 because of the hassle factor of moving and selling large speakers, this is a no-brainer move.
Please don't base this on an idea or a set up that is not in your room. MBLs 101Es do not need subs. Call Jeremy Brian at MBL NA, ask him. If you want MKIIs, a special built exact tolerance and famous set, PM me. I might consider letting this very special low mileage pair go to the right guy.
Hi Peter,
I think the question is whether you find a stand-alone equalizer to blend the subs and 101 Mk1's, or a subwoofer pair with the correct high pass filter that will most closely match the slope of your MBL's lowest octave. if you can find a subwoofer with the right high pass filter it should be easy to hook up assuming your pre has multiple outputs.
always with this direction you are looking for minimal compromise, but know that compromise you will. and that is due to the fact the 101 Mk1's are designed to be full bodied in the lowest octave, and most any sub is also designed to do the same thing. so doubling frequencies is almost inevitable. the question becoming how to get the least doubling.
you might ask MBL what sub have they seen that works the best. they might have a good answer, and they might not want to get involved at all. but it won't hurt to ask.
I totally agree with your desire to improve low frequency performance; the better it is, the better the music is. I sure love what my system does there.
Hi Peter,
Not correct. You will not "double" frequencies by using a sub. Your very own MM7 have a full range main speaker and what is after all a sub ... No doubling.
@Peter
People could say the same for speakers such as the Wilson Alexandrias or the Magico Q7 .. Adding a sub or better at least a pair bring those speakers' already superb performance to a much higher level. Heard both with and without subs ... To use an audiophile cliche: Night and Day
That is not to say that it is a walk-in-the-park kind of thing to integrate subs with any speaker. It will require a lot of work, reading, measuring (yes MEASURING) and learning. The results will always be better than without subs. Objectively and subjectively.
One of the few times I find myself agreeing with you... I would however replace MBL 101 with any speaker (especially) full range. There are obvious exceptions ... Gen 1.x , MM7 or other similar beast may likely not need a sub otherwise ...
What subwoofer do you recommend to go with 101? Q18?
